industry-department-solutions
このコンテンツは選択された言語でご利用になれません。代わりに、英語のコンテンツが表示されます。
Product Category
product_category API resource representing product categories in the B2C pricing application, with parent-child hierarchical structure support.
Overview​
The product_category resource represents product categories in the B2C pricing application. This resource supports hierarchical category structures with parent-child relationships.
Resource Endpoint​
/api/v2/ingest/object/{prefix}PRODUCT_CATEGORY{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) product category records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • product_category_id (string) - Unique identifier for the product category
Attributes​
About Required + Nullable: every attribute key must appear in each payload (Required: Yes). Nullable: Yes means the value can be null when you don't have data; Nullable: No means a non-null value is required. See Schema definition structure for the underlying rules.
AttributeData TypeRequiredNullableDescription
product_category_idstringYesNoUnique product category identifier (Primary Key)
namestringYesYesDisplay name of the category
metadatastringYesYesAdditional metadata or attributes in JSON format
parent_product_category_idstringYesYesReference to the parent category, for hierarchical structure
created_attimestampYesYesTimestamp when the record was created
updated_attimestampYesYesTimestamp when the record was last updated
Relationships​
Outbound References​
This resource has relationships to:
  • product - Categories can contain multiple products
  • product_category (self-reference) - Categories can have child categories
Inbound References​
  • product_category (self-reference) - parent_product_category_id points to a parent category to form hierarchies — a logical reference, not an enforced foreign key
JSON Representation​
  "solutionName": "MP_OOTB",
  "data": [
      "product_category_id": "CAT-ELEC",
      "name": "Electronics",
      "metadata": "{\"display_order\": 1, \"is_featured\": true}",
      "parent_product_category_id": null,
      "created_at": "2025-01-10T08:00:00Z",
      "updated_at": "2025-01-28T10:00:00Z"
  "operationType": "UPSERT"
  "data": [
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/MP_PRODUCT_CATEGORY_OOTB' \
  -d '{
    "data": [
curl -X POST \
  -d '{
    "data": [
Important Notes​
  • Primary Key: This resource uses product_category_id as the primary key
  • Hierarchical Structure: The parent_product_category_id enables multi-level category trees
  • Self-Referencing: Categories can reference other categories as parents
  • Flexible Metadata: The metadata field allows storing additional structured information
  • Custom Attributes: Additional custom attributes can be added using the /PRODUCT_CATEGORY/add-attribute endpoint
  • Data Validation: All attributes are validated according to their defined data types
接続
ヘルプ リソース サポート
学習する UiPath アカデミー
質問する UiPath フォーラム
最新情報を取得
