industry-department-solutions
このコンテンツは選択された言語でご利用になれません。代わりに、英語のコンテンツが表示されます。
Data Types
Data types supported by the Supply Chain & Retail Solutions Data Ingestion API when specifying field schemas for resources.
The Data Ingestion API supports the following data types when specifying the schema of the data being sent. For a full breakdown of the required request payload and which data types apply to each field, see:
Data TypeDescriptionExtra Requirements
stringText/string values (Limit for Redshift: 65535; for Snowflake same as the warehouse default)None
integerWhole number valuesNone
booleanTrue/false valuesNone
floatFloating-point numbersNone — precision and scale are not accepted for float and will be rejected at schema save
numericPrecise decimal numbersRequires precision (1–38) and scale (0–37)
jsonArbitrary JSON values — stored as Snowflake VARIANT / Redshift SUPERNone
dateDate values (no time component)Requires a timestampFormat validation with format: "YYYY-MM-DD"
timestampDate + time valuesRequires a timestampFormat validation with format: "YYYY-MM-DD HH:MI:SS" or format: "YYYY-MM-DD HH:MI:SS ±hh:mm"
Data Type Categories​
CategoryTypesAdditional Required Fields
Basic Typesstring, integer, boolean, float, jsonNone beyond standard validations
Numeric Typesnumericprecision (number), scale (number)
Date/Time Typesdate, timestamptimestampFormat validation with format field
  • Data Type Categories​
接続
ヘルプ リソース サポート
学習する UiPath アカデミー
質問する UiPath フォーラム
最新情報を取得
