OpenShift の Automation Suite のインストール ガイド
最終更新日時 2026年3月26日
出力例: 前提条件の確認
次の例は、Automation Suite のインストールの一部としてインフラストラクチャの前提条件を確認した後に表示される可能性がある出力を示しています。詳しくは、「 インフラストラクチャの前提条件を確認する」をご覧ください。
 ℹ️  [empty-app] Creating Argo CD application for component empty-app...
 ℹ️  [empty-app] Waiting for Argo CD application for component empty-app to synchronize...
Ran cluster/ checks...
    Ran ORCHESTRATOR(CLASSIC_FOLDERS) checks...
        ✔ successful
Ran local/ checks...
    Ran ARGO checks...
        ✔ successful
    Ran CONNECTIVITY checks...
        ✔ successful
    Ran DEPLOYMENT_PROFILE checks...
        ✔ successful
    Ran DNS(FQDN=APPS.<FQDN>) checks...
        ✔ successful
    Ran DNS(FQDN=INSIGHTS.<FQDN>) checks...
        ✔ successful
    Ran INGRESS checks...[INGRESS][UIPATH_GATEWAY_NOT_FOUND] Istio service found but gateway main-gateway not found in uipath namespace
    Ran NAMESPACE checks...
        ✔ successful
    Ran NETWORK-POLICIES checks...
        ✔ successful
    Ran NODE(CPU >= 8, RAM >= 16G) checks...[NODE(CPU >= 8, RAM >= 16G)][LIST_NODES] Listed 4 nodes
        ✔ [AT_LEAST_ONE_NODE] At least one node found
        ✔ [CPU_USAGE] Node os7140768-7db2g-master-0 has 37.50% CPU usage
        ✔ [MEMORY_USAGE] Node os7140768-7db2g-master-0 has 46.35% memory usage
        ✔ [POD_USAGE] Node os7140768-7db2g-master-0 has 0.00% of pods in use. Number of pods: 0.00 max allowed: 250.00[CPU_CAPACITY(os7140768-7db2g-master-0)] Node has enough CPU capacity. Has: 8, needs at least: 8[RAM_CAPACITY(os7140768-7db2g-master-0)] Node has enough RAM capacity. Has: 32868564Ki, needs at least: 16G
        ✔ [CPU_USAGE] Node os7140768-7db2g-worker-eastus1-l6c5p has 12.50% CPU usage
        ✔ [MEMORY_USAGE] Node os7140768-7db2g-worker-eastus1-l6c5p has 13.64% memory usage
        ✔ [POD_USAGE] Node os7140768-7db2g-worker-eastus1-l6c5p has 0.40% of pods in use. Number of pods: 1.00 max allowed: 250.00[CPU_CAPACITY(os7140768-7db2g-worker-eastus1-l6c5p)] Node has enough CPU capacity. Has: 16, needs at least: 8[RAM_CAPACITY(os7140768-7db2g-worker-eastus1-l6c5p)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ✔ [CPU_USAGE] Node os7140768-7db2g-worker-eastus2-p89lq has 6.25% CPU usage
        ✔ [MEMORY_USAGE] Node os7140768-7db2g-worker-eastus2-p89lq has 8.30% memory usage
        ✔ [POD_USAGE] Node os7140768-7db2g-worker-eastus2-p89lq has 0.40% of pods in use. Number of pods: 1.00 max allowed: 250.00[CPU_CAPACITY(os7140768-7db2g-worker-eastus2-p89lq)] Node has enough CPU capacity. Has: 16, needs at least: 8[RAM_CAPACITY(os7140768-7db2g-worker-eastus2-p89lq)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ✔ [CPU_USAGE] Node os7140768-7db2g-worker-eastus3-d6jj5 has 18.75% CPU usage
        ✔ [MEMORY_USAGE] Node os7140768-7db2g-worker-eastus3-d6jj5 has 11.11% memory usage
        ✔ [POD_USAGE] Node os7140768-7db2g-worker-eastus3-d6jj5 has 0.80% of pods in use. Number of pods: 2.00 max allowed: 250.00[CPU_CAPACITY(os7140768-7db2g-worker-eastus3-d6jj5)] Node has enough CPU capacity. Has: 16, needs at least: 8[RAM_CAPACITY(os7140768-7db2g-worker-eastus3-d6jj5)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ⚠  [AS_ROBOTS_NODE_EXISTS] No dedicated node found
    Ran OSS(COMPONENT=CERT-MANAGER) checks...
        ✔ successful
    Ran OSS(COMPONENT=GATEKEEPER) checks...
        ✔ successful
    Ran OSS(COMPONENT=ISTIO) checks...
        ✔ successful
    Ran PERMISSION checks...
        ✔ successful
    Ran PRIORITYCLASS checks...
        ✔ successful
    Ran REGISTRY_PULL checks...
        ✔ successful
    Ran RESOURCE checks...
        ✔ successful
    Ran SECRETS checks...
        ✔ successful
    Ran STORAGECLASS(NAME=STORAGE_CLASS) checks...
        ✔ successful
    Ran STORAGECLASS(NAME=STORAGE_CLASS_SINGLE_REPLICA) checks...
        ✔ successful
Ran nodes/ checks...
Ran CONTROLPLANECONNECTIVITY checks...4/4 nodes successful
Ran DNS(FQDN=APPS.<FQDN>) checks...4/4 nodes successful
Ran DNS(FQDN=INSIGHTS.<FQDN>) checks...4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=BA) checks...4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=DATASERVICE) checks...4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=ORCHESTRATOR) checks...4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=PLATFORM) checks...4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=TESTMANAGER) checks...4/4 nodes successful
Ran REDIS(PORT=6380) checks...4/4 nodes successful
Ran SQL(PRODUCT=ASROBOTS, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=AUTOMATIONHUB, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=AUTOMATIONOPS, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=BA, TYPE=ODBC) checks...4/4 nodes successful
Ran SQL(PRODUCT=DATASERVICE, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=INSIGHTS, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=NOTIFICATIONSERVICE, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=ORCHESTRATOR, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=PLATFORM, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=TESTMANAGER, TYPE=ADO) checks...4/4 nodes successful
Checks complete!
        ✔ successful
    Ran ARGO checks...
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
     ⚠  [INGRESS]
        ⚠  [UIPATH_GATEWAY_NOT_FOUND] Istio service found but gateway main-gateway not found in uipath namespace
        ✔ successful
        ✔ successful
     ⚠  [NODE(CPU >= 8, RAM >= 16G)]
        ✔ [LIST_NODES] Listed 4 nodes
        ✔ [CPU_CAPACITY(os7140768-7db2g-master-0)] Node has enough CPU capacity. Has: 8, needs at least: 8
        ✔ [RAM_CAPACITY(os7140768-7db2g-master-0)] Node has enough RAM capacity. Has: 32868564Ki, needs at least: 16G
        ✔ [CPU_CAPACITY(os7140768-7db2g-worker-eastus1-l6c5p)] Node has enough CPU capacity. Has: 16, needs at least: 8
        ✔ [RAM_CAPACITY(os7140768-7db2g-worker-eastus1-l6c5p)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ✔ [CPU_CAPACITY(os7140768-7db2g-worker-eastus2-p89lq)] Node has enough CPU capacity. Has: 16, needs at least: 8
        ✔ [RAM_CAPACITY(os7140768-7db2g-worker-eastus2-p89lq)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ✔ [CPU_CAPACITY(os7140768-7db2g-worker-eastus3-d6jj5)] Node has enough CPU capacity. Has: 16, needs at least: 8
        ✔ [RAM_CAPACITY(os7140768-7db2g-worker-eastus3-d6jj5)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
 ✔ 4/4 nodes successful
Checks complete!
接続
ヘルプ リソース サポート
学習する UiPath アカデミー
質問する UiPath フォーラム
最新情報を取得
