最終更新日時 2026年3月9日
Automation Suite 2024.10.0 へのアップグレード後に Automation Hub にアクセスできない
説明
Automation Suite 2024.10.0 へのアップグレード後は、Automation Hub にアクセスできなくなります。 この問題は、Automation Suite 2024.10.1 以降のバージョンには影響しません。
解決策
この問題を解決するには、 AutomationSuite_Automation_Hub データベースで次の SQL スクリプトを実行する必要があります。
-- IMPORTANT:
-- This script should be executed in the AutomationSuite_Automation_Hub database.
-- Purpose:
-- This script resolves potential issues encountered during the upgrade to version 2024.10.0 of Automation Hub.
-- Please replace placeholders with actual data before running the script.
-- Assumptions:
-- The customer has an existing Automation Hub instance running a version prior to 2024.10.0.
-- Variables:
-- @AccountName: Logical name of the Automation Suite organization. Replace '<USER_INPUT>' with the actual name.
-- @TenantName: Logical name of the Automation Suite tenant. Replace '<USER_INPUT>' with the actual name.
-- Note:
-- The script will terminate if any errors occur and will provide error details for debugging.
SET XACT_ABORT ON;
-- Replace placeholders with actual values
DECLARE @AccountName NVARCHAR(255) = '<USER_INPUT>';
DECLARE @TenantName NVARCHAR(255) = '<USER_INPUT>';
-- DO NOT EDIT ANYTHING AFTER THIS POINT --
BEGIN TRY
    BEGIN TRANSACTION;
    -- Validate placeholders
    IF @AccountName = '<USER_INPUT>' OR
       @TenantName = '<USER_INPUT>'
    BEGIN
        RAISERROR('Placeholders were not replaced with actual values. Please update the script and retry.', 16, 1);
        RETURN;
    END;
    -- Declare variables for tenant information
    DECLARE @TenantUUID NVARCHAR(255);
    DECLARE @TsTablePrefix NVARCHAR(255);
    -- Retrieve tenant_uuid from the cloud_tenants table based on TenantName and AccountName
    DECLARE @sql NVARCHAR(MAX);
    DECLARE @params NVARCHAR(MAX);
    SET @sql = N'SELECT @TenantUUID = tenant_uuid
                  FROM ah.cloud_tenants
                  WHERE cloud_TenantName = @TenantName
                    AND cloud_AccountName = @AccountName;';
    SET @params = N'@TenantName NVARCHAR(255), @AccountName NVARCHAR(255), @TenantUUID NVARCHAR(255) OUTPUT';
    EXEC sp_executesql @sql,
                       @params,
                       @TenantName = @TenantName,
                       @AccountName = @AccountName,
                       @TenantUUID = @TenantUUID OUTPUT;
    -- Abort if tenant_uuid is not found
    IF @TenantUUID IS NULL
    BEGIN
        RAISERROR('No tenant found for the provided TenantName and AccountName. Script execution aborted.', 16, 1);
        RETURN;
    END;
    -- Retrieve tenant_db_table_prefix from tenants table using tenant_uuid
    SET @sql = N'SELECT @TsTablePrefix = tenant_db_table_prefix
                  FROM ah.tenants
                  WHERE tenant_uuid = @TenantUUID;';
    SET @params = N'@TenantUUID NVARCHAR(255), @TsTablePrefix NVARCHAR(255) OUTPUT';
                       @params,
                       @TenantUUID = @TenantUUID,
                       @TsTablePrefix = @TsTablePrefix OUTPUT;
    -- Abort if tenant_db_table_prefix is not found
    IF @TsTablePrefix IS NULL
    BEGIN
        RAISERROR('No tenant found in the tenants table for the provided tenant_uuid. Script execution aborted.', 16, 1);
        RETURN;
    END;
    -- Drop the default constraint for assignment_days column
    DECLARE @ConstraintName NVARCHAR(200);
    SELECT @ConstraintName = dc.name
    FROM sys.default_constraints dc
        INNER JOIN sys.columns c
            ON dc.parent_object_id = c.object_id
           AND dc.parent_column_id = c.column_id
    WHERE c.object_id = OBJECT_ID(@TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates')
        AND c.name = 'assignment_days';
    IF @ConstraintName IS NOT NULL
    BEGIN
        EXEC('ALTER TABLE ' + @TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates DROP CONSTRAINT [' + @ConstraintName + ']');
    END;
    -- Recreate the default constraint for assignment_days
    DECLARE @UniqueConstraintName NVARCHAR(255) = '[' + @TsTablePrefix + 'DF_assignment_days]';
    BEGIN
        EXEC('ALTER TABLE ' + @TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates ADD CONSTRAINT ' + @UniqueConstraintName + ' DEFAULT 0.00 FOR assignment_days');
    END
    -- Drop the index on the assignment_days column
    IF EXISTS (SELECT 1
               FROM sys.indexes
               WHERE name = 'assignment_days'
                 AND object_id = OBJECT_ID(@TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates')
    BEGIN
        EXEC('DROP INDEX assignment_days ON ' + @TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates');
    END;
    -- Alter the assignment_days column
    EXEC('ALTER TABLE ' + @TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates ALTER COLUMN assignment_days NUMERIC(15, 2) NOT NULL');
    -- Recreate the index on assignment_days
    EXEC('CREATE NONCLUSTERED INDEX assignment_days ON ' + @TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates (assignment_days ASC)');
    -- Insert a record into the migrations table
    EXEC('INSERT INTO ' + @TsTablePrefix + 'migrations (name, run_on) VALUES (''tenants/20230925145641-edit-cba-one-time-costs-estimates-table-column'', CURRENT_TIMESTAMP)');
    -- Commit the transaction
    COMMIT TRANSACTION;
    PRINT 'Script executed successfully.';
END TRY
BEGIN CATCH
    IF @@TRANCOUNT > 0
        ROLLBACK TRANSACTION;
    -- Output error details
    PRINT 'Error occurred during script execution:';
    PRINT 'Error Number: ' + CAST(ERROR_NUMBER() AS VARCHAR(10));
    PRINT 'Error Severity: ' + CAST(ERROR_SEVERITY() AS VARCHAR(10));
    PRINT 'Error State: ' + CAST(ERROR_STATE() AS VARCHAR(10));
    PRINT 'Error Procedure: ' + ISNULL(ERROR_PROCEDURE(), '');
    PRINT 'Error Line: ' + CAST(ERROR_LINE() AS VARCHAR(10));
    PRINT 'Error Message: ' + ERROR_MESSAGE();
END CATCH;
-- IMPORTANT:
-- Purpose:
-- Assumptions:
-- Variables:
-- Note:
SET XACT_ABORT ON;
BEGIN TRY
    BEGIN TRANSACTION;
    BEGIN
        RETURN;
    END;
                       @params,
    BEGIN
        RETURN;
    END;
                  FROM ah.tenants
                       @params,
    BEGIN
        RETURN;
    END;
    BEGIN
    END;
    BEGIN
    END
    IF EXISTS (SELECT 1
               FROM sys.indexes
    BEGIN
    END;
    COMMIT TRANSACTION;
END TRY
BEGIN CATCH
    IF @@TRANCOUNT > 0
END CATCH;
  • 説明
  • 解決策
接続
ヘルプ リソース サポート
学習する UiPath アカデミー
質問する UiPath フォーラム
最新情報を取得
