uipathctl リファレンス ガイド
uipathctl sso generate-connector
説明​
Generate configuration files for Dex connectors. For a complete list of valid connector types and more information about each field, see Dex documentation.
uipathctl sso generate-connector [flags]
Generate an empty configuration for an LDAP connector:
  uipathctl sso generate-connector -t ldap
オプション​
  -h, --help                  help for generate-connector
  -t, --type connector-type   the type of connector (default ldap)
親コマンドから継承されるオプション​
接続
最新情報を取得
