- 概要
- 要件
- インストール
- 前提条件の確認
- インストール パッケージをダウンロードする
- uipathctl cluster
- uipathctl cluster upgrade
- uipathctl config
- uipathctl config alerts
- uipathctl health
- uipathctl health bundle
- uipathctl health check
- uipathctl health diagnose
- uipathctl health test
- uipathctl identity
- uipathctl identity add-host-admin
- uipathctl identity enable-basic-auth
- uipathctl manifest
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- uipathctl resource
- uipathctl resource report
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl sso
- uipathctl sso generate-connector
- uipathctl sso generate-overlays
- uipathctl sso generate-rbac
- uipathctl version
- インストール後
- 移行とアップグレード
- 監視とアラート機能
- クラスターの管理
- 製品固有の設定
- トラブルシューティング
Last updated 2024年9月20日
ファブリックの SSO デプロイ用の Kustomize オーバーレイを生成します。
uipathctl sso generate-overlays [flags]
Generate the overlays for a HA deployment of both ArgoCD and Dex, loading RBAC from a file
uipathctl sso generate-overlays --argocd-base ha --dex-base ha --argocd-url <https://argocd.local:30001> --rbac-file test-policies.csv --connector-file connector.yaml --dex-url <https://dex.local:32000> --kustomize-root ./hack/test/sso/kustomize
--argocd-base string ArgoCD kustomize base directory to use
--argocd-url string The externally accessible URL for ArgoCD (must include port if not standard for protocol)
--connector-file string Path to the Dex Connector's configuration file
--dex-base string Dex base kustomization to use
--dex-url string The externally accessible URL for Dex
--dex-use-https Optionally use https for Dex
-h, --help help for generate-overlays
--kustomize-root string Kustomize root directory
--rbac-file string Optional file to load the RBAC config for ArgoCD from (Overwrites policy.csv in the argocd-rbac-cm ConfigMap)
