- 概要
- 要件
- インストール
- 前提条件の確認
- インストール パッケージをダウンロードする
- uipathctl cluster
- uipathctl cluster upgrade
- uipathctl config
- uipathctl config alerts
- uipathctl health
- uipathctl health bundle
- uipathctl health check
- uipathctl health diagnose
- uipathctl health test
- uipathctl identity
- uipathctl identity add-host-admin
- uipathctl identity enable-basic-auth
- uipathctl manifest
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- uipathctl resource
- uipathctl resource report
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl sso
- uipathctl sso generate-connector
- uipathctl sso generate-overlays
- uipathctl sso generate-rbac
- uipathctl version
- インストール後
- 移行とアップグレード
- 監視とアラート機能
- クラスターの管理
- 製品固有の設定
- トラブルシューティング
Last updated 2024年9月20日
Automation Suite の問題のトラブルシューティングに使用できるサポート バンドルを生成します。
uipathctl health bundle [PATH] [flags]
# Generate the bundle in the OS temporary directory
uipathctl health bundle input.json
# Generate the bundle in a specific directory
uipathctl health bundle input.json --output-dir /foo/bar
# Generate the bundle without additional health/prereq report
uipathctl health bundle input.json --skip-diagnose
-h, --help help for bundle
-p, --include-previous If false, skips printing the logs for the previous instance of the container in a pod if it exists. (default true)
--limit-bytes int Maximum bytes of logs to return. Defaults to no limit.
--output-dir string path to output directory
--since-time string Only return logs after a specific date (RFC3339). Defaults to all logs.
--skip-diagnose skip additional health/prereq report
--versions string path to versions file
--excluded strings components to be excluded from execution, defaults to none
--included strings components to be included in the execution, defaults to all
-o, --output output output format. one of [json,yaml,text,junit] (default text)
