# SQL connection string validation error
> SQL connection string validation error that occurs despite correct credentials in Automation Suite and how to resolve it.
## Description
You might receive an error relating to the connection strings as follows:
Sqlcmd: Error: Microsoft Driver 17 for SQL Server :
Server-tcp : <connection string>
Login failed for user
This error appears even though all credentials are correct. The connection string validation failed.
## Solution
Make sure the connection string has the following structure:
Server=<Sql server host name>;User Id=<user_name for sql server>;Password=<Password>;Initial Catalog=<database name>;Persist Security Info=False;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;
:::note
`User Id` is case-sensitive.
