# uipathctl prereq create
> Create external prerequisites like databases and storage buckets in Automation Suite.
## Description
Creates the external prerequisites. These are primarily object storage buckets and SQL databases. The SQL databases required for the installation are created on the SQL server if the `sql.create_db key` is set in the config file. The object storage buckets are created in the cloud provider if the `object_storage.create_bucket` key is set in the config file.
uipathctl prereq create PATH [flags]
## Examples
# Create all external prerequisites
uipathctl prereq create input.json/cluster_config.json --versions versions.json
## Options
  -h, --help                help for create
      --location location   Location where the prerequisites are executed. one of [local, cluster] (default cluster)
  -o, --output output       output format. one of [json,yaml,text] (default text)
      --versions string     Path to the versions file
## Options inherited from parent commands
      --excluded strings    components to be excluded from execution, defaults to none
      --included strings    components to be included in the execution, defaults to all
      --upgrade             include upgrade-related checks
