# Create external client
> Create a new external OAuth client in an Automation Suite organization using the Identity API, including required scope and request body fields.
Create a new external client.
## API endpoint
`POST https://{yourDomain}/{organizationName}/identity_/api/ExternalClient`
## Scopes
Requires either one of the following scopes:
* `PM.OAuthApp`
* `PM.OAuthApp.Write`
## Request headers
:::note
To obtain the `{access_token}`, make sure to authenticate through one of the methods described in [Authentication methods](https://docs.uipath.com/automation-suite/automation-suite/2.2510/api-guide/authentication-methods#authentication-methods).
## Request body
The request body includes the organization ID, the external client name, its confidentiality status, the redirect URI, the required scopes, and the client certificates.
  "partitionGlobalId": "orgId",
  "name": "string",
  "isConfidential": true,
  "redirectUri": "string",
  "scopes": [
      "name": "string",
      "displayName": "string",
      "description": "string",
      "type": "user"
  "clientCertificates": [
## Responses
### 201 Created
The external client has been successfully created.
  "name": "string",
  "id": "string",
  "secret": "string",
  "resources": [
      "name": "string",
      "scopes": [
          "name": "string",
          "type": "user"
  "secrets": [
      "id": 0,
      "secret": "string",
      "creationTime": "2025-07-18T13:53:12.823Z",
      "expiryTime": "2025-07-18T13:53:12.823Z"
