# Get settings
> Retrieve email and authentication settings for an Automation Suite organization as key-value pairs using the Identity API, including required scope and response schema.
Use this endpoint to retrieve the list of key-value pairs for email and authentication settings.
## API endpoint
`GET` `https://{yourDomain}/{organizationName}/identity_/api/Setting`
## Scopes
Requires the following scopes:
* `PM.Setting`
* `PM.Setting.Read`
## Request headers
:::note
To obtain the `{access_token}`, make sure to authenticate through one of the methods described in [Authentication methods](https://docs.uipath.com/automation-suite/automation-suite/2.2510/api-guide/authentication-methods#authentication-methods).
## Query parameters
| Parameter | Data type | Description |
| `key` | String | **Optional.**Enter the name of the setting you want to retrieve.  For example, to retrieve the SMTP Domain setting, enter `key=Email.Smtp.Domain`. |
| `partitionGlobalId` | String | **Optional.**The ID of the organization you want to retrieve the settings for. |
| `userId` | String | **Optional.**The ID of the user you want to retrieve the settings for. |
## Responses
### 200 OK
Returns the queried robot accounts.
## Example request
Let's say you gathered all the information needed to build the API call.
* Your `{baseURL}` is: `https://{yourDomain}/{organizationName}/identity_`
* Your `{access_token}` is: `1234` (for length considerations).
* The `{partitionGlobalId}` is: `3fa85f64-5717-4562-b3fc-2c963f66afa6`
* You want to retrieve the global email settings, so you log in as the host admin. In this case, you don't provide a `userID`.
The call should resemble the following example (cURL):
curl --location --request GET 'https://{yourDomain}/{organizationName}/identity_/api/Setting?partitionGlobalId=3fa85f64-5717-4562-b3fc-2c963f66afa6&key=Email.Smtp.Domain&key=Email.Smtp.EnableSsl&key=Email.Smtp.FromDisplayName&key=Email.Smtp.FromEmail&key=Email.Smtp.Host&key=Email.Smtp.Password&key=Email.Smtp.Port&key=Email.Smtp.UseDefaultCredentials&key=Email.Smtp.UserName' \
Here's the response body for a successful call:
        "id": 6,
        "key": "Email.Smtp.FromEmail",
        "value": "newalerts.uipath@gmail.com",
        "partitionGlobalId": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
        "userId": null
        "id": 7,
        "key": "Email.Smtp.FromDisplayName",
        "value": "Hogwarts server - 21.10 - Clean",
        "userId": null
        "id": 15,
        "key": "Email.Smtp.Domain",
        "value": "",
        "userId": null
        "id": 16,
        "key": "Email.Smtp.EnableSsl",
        "value": "true",
        "userId": null
        "id": 17,
        "key": "Email.Smtp.Port",
        "value": "587",
        "userId": null
        "id": 18,
        "key": "Email.Smtp.UseDefaultCredentials",
        "value": "false",
        "userId": null
        "id": 19,
        "key": "Email.Smtp.UserName",
        "userId": null
        "id": 20,
        "key": "Email.Smtp.Host",
        "value": "smtp.gmail.com",
        "userId": null
        "id": 21,
        "key": "Email.Smtp.Password",
        "value": "protego-spell",
        "userId": null
