# General Workflow Analyzer Settings
> * **Allow users to override** - If enabled, users are allowed to make changes to Workflow Analyzer settings. This option is not enabled by default.
* **Referenced or embedded** - Select how to define the settings for Workflow Analyzer rules and counters in the policy:
  * **Referenced** - Define the settings using a JSON file configured similarly to the [RuleConfig.json](https://docs.uipath.com/studio/docs/about-workflow-analyzer#configure-rules) file. If you select this option, indicate the full path to the file in the **Referenced Rules file** box. The location must be accessible from the Studio machines.
  * **Embedded** - Define the settings using the options on the policy page. This is the default option.
