Introduction
Development in UiPath Process Mining is done collaboratively. To facilitate this, and to keep track of changes, Git is used. A Git server can be used by multiple installations of UiPath Process Mining.
There are two methods in which you can incorporate Git:
- A local Git repository, managed by UiPath Process Mining.
- A Git repository you manage yourself. This can either be your own Git server, or even a GitHub repository.
Important
Whichever Git repository you choose to use, you should make sure to only make changes through UiPath Process Mining. Performing Git operations manually (e.g. through the Git command-line tools) may interfere with the proper operation of UiPath Process Mining.
Local repository
Follow these steps to use a local repository within the UiPath Process Mining installation.
Step | Action |
1 | Login on the Superadmin page. |
2 | Go to the Settings tab. |
3 | In the Repositories text field, use the following value: |
4 | Press CTRL+S to save the changes and reload the page to apply them. |
Username and password
Follow these steps to use a Github account using a username and password.
Step | Action |
1 | Go to the Settings tab. |
2 | In the Repositories text field, use the following value:
3 | Press CTRL+S to save the changes and reload the page to apply them. |
Hide password
In case you do not want passwords clearly visible in the settings, you can also use a public and private key pair. You will need access to the filesystem of the server.
Follow these steps to use public and private key repair.
Step | Action |
1 | Obtain public and private keys for the Github repository you want to use. |
2 | Place them in the databases directory in . It is recommended to place them in a subdirectory, for example, respectively for the private and public keys: • |
3 | Go to the Settings tab. |
4 | In the Repositories text field, use the following value:
Replace the URL with the actual URL you want to use. If the location of your keys differs from step 2, change the values accordingly. |
5 | Press |
A Git server is connected to UiPath Process Mining. Your developers can start committing and collaborating.
Updated 4 months ago
