License
Important
If you want to install UiPath Process Mining or any of its components, you need
access to an environment, and you need a UiPath Process Mining license. Please
consult your UiPath Process Mining contact.
Windows Server
It is recommended to use a clean installation of Windows Server.
See Hardware and Software Requirements for the supported versions.
For production environments we recommend using CPUs with high single threaded performance, an SSD for storage, and enough RAM.
Web browser
A supported web browser must be installed on the UiPath Process Mining server. See Hardware and Software Requirements below for the supported versions.
Folder Compression
Cache files use a lot of disk space. To save disk space, it is strongly recommended to set the Compress contents to save disk space option for the UiPath Process Mining server installation folder.
Follow these steps to set the Compress contents to save disk space option.
Step | Action |
1 | In Windows Explorer, right click on the UiPath Process Mining installation folder and select Properties.... |
2 | On the General tab, click on Advanced.... |
3 | Enable the Compress contents to save disk space option and click on OK (2x). |
Note
If you enable the Compress contents to save disk space option, you cannot enable the Encrypt contents to secure data option.
Updated about a month ago
