industry-department-solutions
Currency Conversion
currency_conversion API resource storing exchange rates between currency pairs for cross-region price normalization in the Merchandising solution.
Overview​
The currency_conversion resource stores exchange rates between currency pairs. The Merchandising solution uses these rates to normalise prices, sales values, and stock values to a common reporting currency when a tenant operates across multiple regions.
Resource Endpoint​
/api/v2/ingest/object/{prefix}CURRENCY_CONVERSION{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) currency-conversion records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • from_currency (string) - ISO currency code being converted from
  • to_currency (string) - ISO currency code being converted to
  • created_at (timestamp) - Timestamp when the rate record was created — part of the PK so successive rate updates for the same pair are distinct rows
Attributes​
About Required + Nullable: every attribute key must appear in each payload (Required: Yes). Nullable: Yes means the value can be null when you don't have data; Nullable: No means a non-null value is required. See Schema definition structure for the underlying rules.
AttributeData TypeRequiredNullableDescription
from_currencystringYesNoISO currency code the exchange rate is converting from (e.g., USD). Primary Key.
to_currencystringYesNoISO currency code the exchange rate is converting to (e.g., GBP). Primary Key.
exchange_ratefloatYesNoExchange rate to apply — 1 from_currency = exchange_rate to_currency.
updated_attimestampYesYesTimestamp when the record was last updated.
created_attimestampYesNoTimestamp when the rate was recorded (Primary Key).
Relationships​
Outbound References​
None
Inbound References​
None
JSON Representation​
  "solutionName": "MP_OOTB",
  "data": [
      "from_currency": "USD",
      "to_currency": "GBP",
      "exchange_rate": 0.79,
      "updated_at": "2025-01-28T10:00:00Z",
      "created_at": "2025-01-28T10:00:00Z"
  "operationType": "UPSERT"
  "data": [
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/MP_CURRENCY_CONVERSION_OOTB' \
  -d '{
    "data": [
curl -X POST \
  -d '{
    "data": [
Important Notes​
  • Direction matters: a rate is one-way — USD → GBP and GBP → USD are separate rows. Send both directions if your downstream needs to convert both ways.
  • Historical rates: created_at is part of the primary key so you can ingest a new rate for the same pair at any time without overwriting the old rate; downstream picks the latest by created_at.
  • Currency codes: use 3-letter ISO 4217 codes (e.g., USD, GBP, EUR) for both from_currency and to_currency. The same code should be used in the location resource's currency field.
  • Custom Attributes: Additional custom attributes can be added using the /CURRENCY_CONVERSION/add-attribute endpoint.
  • Data Validation: All attributes are validated according to their defined data types.
  • location - Location's currency comes from this code set
  • sale - Sales values that may need conversion to a common reporting currency
  • product_pricing_daily - Prices that may need conversion to a common reporting currency
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
