# Analyze test results
> Analyze test executions in Test Manager by reviewing execution entries per test set and understanding the underlying execution process.
To view test executions, open **Execution** in Test Manager. The execution of each test set is listed as a test execution entry. To understand how the test executions work behind the scenes, see [Execution](https://docs.uipath.com/test-manager/automation-suite/2024.10/user-guide/test-results).
By analyzing your test execution, you can take the following actions:
* Find test results that have been executed manually or automatically through Orchestrator.
* Check the progress on running test executions.
* Open the test set that has been executed.
* Examine logs and attachments.
* Create defects in your defect management system directly from Test Manager, if you have an Application Lifecycle Management tool integration. For more information, see [ALM Tool Integration](https://docs.uipath.com/test-manager/automation-suite/2024.10/user-guide/about-alm-tool-connectors).
By default, the test executions are sorted based on the date on which the execution was finished. Currently running and pending executions are placed at the top.
You can identify the status through the color codes assigned to each test execution, as follows.:
* **Green**: Test cases that passed.
* **Red**: Test cases that failed.
* **Grey**: Test cases without a definitive results, such as test cases that have not been executed yet but are part of a test set that is currently being executed.
## Results from automated tests
The results from automated test executions are imported from Orchestrator automatically. To have your automated tests imported to Test Manager, you need to meet the following conditions:
* The automated test needs to be part of a test set on your Test Manager project. For more information, see [Automated Tests](https://docs.uipath.com/test-manager/automation-suite/2024.10/user-guide/executing-tests#executing-tests).
  :::note
  If a Test Execution from Orchestrator holds results for test cases from several projects in Test Manager, the test execution is split in Test Manager. The results appear in the projects where the test cases are.
## Overriding test results
Overriding the results of a test case can help in scenarios where the current test result does not accurately reflect the actual behavior of the application and re-execution is not an effective solution. You can override the test results of a test case and then you can clear the operation, if needed.
1. Navigate to **Execution** and open a test result.
2. From the **Results** tab open a test case log.
3. In the **Assertions** tab, select **Tasks** &gt; **Override result**.
4. In the **Override test result** window configure the following fields:
   1. **Change result to** - select whether you want to override the result with the opposite status (**Passed**/**Failed**) or set the result to **None**.
   2. **Comment** - Type the reason why you override the result.
5. Select **Confirm**. The test results that you overrode have the following icon next to the test result status: ![](https://dev-assets.cms.uipath.com/assets/images/test-manager/2024-10-image-299312-850fc77a-d77ef193.webp). Select the icon and you can view the override details.
   Figure 1. The "Test result overridden successfully" message
   ![The "Test result overridden successfully" message](https://dev-assets.cms.uipath.com/assets/images/test-manager/2024-10-the-test-result-overridden-successfully-message-463538-9414da13-b03b30bb.webp)
6. Optionally, if you want to clear the override operation, select the ![docs image](https://dev-assets.cms.uipath.com/assets/images/test-manager/2024-10-image-299312-850fc77a-d77ef193.webp) next to the result status of a test case log.
   1. In the **Override details** window, select **Clear override**.
      Figure 2. The **Override details** menu
      ![The Override details menu](https://dev-assets.cms.uipath.com/assets/images/test-manager/2024-10-the-override-details-menu-463542-95aa1adc-748682c2.webp)
7. Optionally, if you want to edit the override operation, select the ![docs image](https://dev-assets.cms.uipath.com/assets/images/test-manager/2024-10-image-299312-850fc77a-d77ef193.webp) next to the result status of a test case log.
   1. Perform changes, and select **Confirm**.
## Navigation and search
To quickly find your test results, use the search function and the filters. Navigate within the page using and configuring the paginator. Alternatively, you can use the breadcrumb to navigate between the pages.
1. **Filters** - You can use the filters to narrow your search. For example, you can search for test results by the following criteria:
   1. Labels
   2. Execution Type
   3. Execution Finished
   4. StatusThe filters are automatically saved and kept active until you clear them.
2. **Search** - Use the search bar to find test results by their key, execution type or status (requires full search term match). You can use the search bar at the top of the page to look for test results.
## Working with test execution results
To view detailed test results, go to **Execution**.
In the **Results** tab, select **View By** and choose your preferred view for test results. You can select one of the following views:
* **Test Set**: Test results are grouped by Test Execution (Test Set).
* **Test Case**: For cross-execution analysis when filtering the results based on criteria excluding test execution attributes.
  ![docs image](https://dev-assets.cms.uipath.com/assets/images/test-manager/2024-10-docs-image-392945-71664648-17319763.webp)
Select an entry to open the detailed view. A typical test execution detailed view shows information on when the executions started, duration, and [execution logs](https://docs.uipath.com/test-manager/automation-suite/2024.10/user-guide/analyzing-test-results#execution-log).
You can use the **Reporting Date** filter to set a unified date across all test results from the test execution. This is useful when you run tests overnight, where some test cases are executed before and after midnight, preventing results from splitting onto separate dates.
In the **Results** tab, you can also:
- Examine all the executed test cases within the test set and take action for each, as necessary. For more information, see the **Execution log** section.
- Open the executed test set by right-clicking an entry in the **Test Sets** page and selecting **Open Test Set**, or directly within the test execution.
## Execution log
As part of test reporting, execution logs hold information such as execution details (e.g., data variation and screenshots), failed and passed assertions, and a detailed log of execution events.
To open a test case log, go to **Executions**, open a test execution and then click a test case **Key**.
Figure 3. Overview of the execution details of a test case log
![Overview of the execution details of a test case log](https://dev-assets.cms.uipath.com/assets/images/test-manager/2024-10-overview-of-the-execution-details-of-a-test-case-log-462295-1acac6a3-26f6fc45.webp)
In the following table, you can view the type of information that is collected during test case execution.
 <colgroup>
  <col/>
  <col/>
 </colgroup>
     Test execution reporting
    Assertions
    View failed or passed assertions (e.g.,  Verify expression activity  ), and associated screenshots if any were taken during test case execution. To make sure that Orchestrator takes screenshots during executions, visit the following resources:
          Default roles in Orchestrator  - to check if the default roles have the Test Case Execution Artifacts permission assigned. In case the default roles don't have this permission, then you can create a custom role with this permission.
          Managing roles in Orchestrator  - to learn how to create, edit, or import a role in Orchestrator.
    Logs
    View INFO level logs as part of the <code>RobotLogs</code> , with information about processes, execution robot, and event logs, including failures.  Select the  icon to go to the Logs tab of the selected test case, for a detailed description of the failure.
    Execution details
    View argument details such as input and output values, as well as execution and robot details (e.g., project, machine, robot).
    Affected requirements
    View the requirements that are assigned to the test case that has been executed. You can use this tab to go directly to the affected requirement.
    View:
         the attachments uploaded using the  Attach Document  activity.
         the attachments of a test case result, that is linked from Orchestrator.
### Downloading execution logs
* To download logs for all your test executions: From **Execution**, select **Export to excel**.
* To download test case logs for a specific test execution: From **Execution**, select a test execution, and then select **Export to excel**.
Visit [Export data](https://docs.uipath.com/test-manager/automation-suite/2024.10/user-guide/export-data#export-data) to check more details about exporting logs to excel files.
## Viewing activity coverage
:::note
Activity coverage is available only for automated test executions.
**Prerequisites**: Enable activity coverage for the desired test sets either in Orchestrator or Test Manager.
1. Open the test set, select **More Options** ![docs image](https://dev-assets.cms.uipath.com/assets/images/test-manager/2024-10-docs-image-more_options_icon_test_manager-f5321fec-e8d350e6.png) and then **Execute Automated**.
2. Go to **Execution** and open the test set you executed.
3. Go to the **Activity Coverage** tab and investigate the information on the activities that were covered during the test execution.
   Figure 4. Overview of an example activity coverage
   ![Overview of an example activity coverage](https://dev-assets.cms.uipath.com/assets/images/test-manager/2024-10-overview-of-an-example-activity-coverage-463531-7b09b7c8-c56bed84.webp)
## Create defects from results
You can create defect reports including the execution log to your external defect management system, if you already have it integrated with Test Manager. For more information, see [ALM Tool Integration](https://docs.uipath.com/test-manager/automation-suite/2024.10/user-guide/about-alm-tool-connectors).
To create a defect out of an execution log, you need to open a test case log, click **Tasks**, and then select **Create Defect**. After the defect has been created, a link is available in the execution log, so you can access the integrated external tool.
## Related articles
* [Bulk Operations](https://docs.uipath.com/test-manager/automation-suite/2024.10/user-guide/bulk-operations#bulk-operations)
* [Export Data](https://docs.uipath.com/test-manager/automation-suite/2024.10/user-guide/export-data#export-data)
