# Test results
> Test results in Test Manager, including execution records and test case logs generated during test set execution in Automation Suite.
When you start executing a test set, Test Manager goes through the following process:
1. A Test Execution is created in the **Execution** section of Test Manager. This serves as the container for the test results.
2. For every test case within the executed test set, an empty Test Case Log is generated. This log is attached to the Test Execution and will hold its associated test results.
3. As the execution continues, the Test Manager fills each Test Case Log with results and related log information.
:::note
Every time a test execution is created, Test Case Logs for all associated test cases from the original test set are added. Furthermore, dynamic assignments are resolved at this stage. This means existing Test Executions remain consistent, regardless of updates or deletions made to the original test set.
The chart below illustrates the process of executing a test set in Test Manager.
![Test set execution process flow in Test Manager](https://dev-assets.cms.uipath.com/assets/images/test-manager/test-manager-docs-image-125339-f05f6894-15d71057.webp)
As a consequence, after a test set has been executed, any changes to the test set or its associated test cases do not affect the results from previous executions. Even when a test set is deleted, all the test executions remain unchanged.
Who can see projects
All user roles can see test results.
For more information see [User and Group Access Management](https://docs.uipath.com/test-manager/automation-suite/2.2510/user-guide/managing-users-and-groups#user-and-group-access-management).
