# Scheduling executions
> Schedule automated test set executions in Test Manager using single, recurrent, or advanced cron-based schedules in Automation Suite.
Plan and manage your automated test executions using customizable schedules. You can create various types of schedules based on the cadence of your test runs. You can configure single schedules for one-time runs, recurrent schedules set with a regular cadence, and advanced schedules configured with Cron expressions. You can manage all your schedules in the **Execution** section of your project, under **Schedules**.
Figure 1. The Schedules tab of your testing project
![The Schedules tab of your testing project](https://dev-assets.cms.uipath.com/assets/images/test-manager/test-manager-the-schedules-tab-of-your-testing-project-520494-e3aeedf2-b6effd2a.webp)
## Prerequisites
To create a schedule for an automated test, you need the **Automated execution** Test Manager permission. When creating a custom Test Manager role, you can find this permission under **Task Permissions**.
:::note
The Test Manager project roles that can create schedules are: **Project owner**, **Test Manager**, and **Test Executor**.
## Creating schedules
To create a schedule for an automated test execution, follow these steps:
1. Go to the **Execution** section of your project, then navigate to **Schedules**.
2. Select **Create Schedule**.
3. Configure your schedule as needed, using the following fields:
   1. **Schedule**: Enter a name for your schedule.
   2. **Test Sets**: From the dropdown list, select an automated test set that you want the schedule to apply to.
   3. **Description**: Enter a description of the schedule.
   4. **Schedule Type**: Depending on the type of schedule you choose, you need to configure additional parameters:
      * **Single**: This type runs only once. Define a **Start date** and a **Time zone**.
      * **Recurrence**: This type runs on a set cadence with a defined start, and end date:
        1. **Repeat**: Select the schedule cadence:
           + **Minutely**: Set the number of minutes for the schedule recurrence.
           + **Hourly**: Set the number of hours for the schedule recurrence.
           + **Daily**: Set the number of days for the schedule recurrence.
           + **Weekly**: Set the number of weeks for the schedule recurrence.
           + **Monthly**: Set the number of months for the schedule recurrence.
        2. **Start date**: Set a start date for the recurrent schedule.
        3. **End date**: Select an end date for the recurrent schedule.
        4. **Time zone**: Select a specific timezone for the schedule.
      * **Advance**: This type runs based on a cadence configured using Cron expressions.
        1. **Cron Expression**: Enter a Cron expression, using Quartz Cron syntax, that represents the schedule recurrence. For example, if you want to configure a schedule that runs every Tuesday, at midnight, you would use the following Quartz Cron expression: `0 0 0 ? * 2`. For more information on Cron expressions, visit [Using Cron expressions](https://docs.uipath.com/orchestrator/automation-suite/2.2510/user-guide/using-cron-expressions).
        3. **Time zone**: Select a specific timezone for the schedule.
4. Select **Save** to create the schedule.
Figure 2. The Create Schedule window
![The Create Schedule window](https://dev-assets.cms.uipath.com/assets/images/test-manager/test-manager-the-create-schedule-window-520590-712b7274-d1273f4b.webp)
## Editing schedules
To edit a schedule, follow these steps:
1. Go to the **Execution** section of your project, under **Schedules**.
2. For the schedule you want to edit, select **More Options** &gt; **Edit**.
3. Re-configure your schedule by changing values for the following fields:
4. Select **Save** to confirm your changes.
## Deactivating schedules
To deactivate an existent schedule, follow these steps:
1. Go to the **Execution** section of your project, and go to **Schedules**.
2. Find the schedule you want to deactivate, then select **More Options** &gt; **Deactivate**. The schedule will remain but will not run. It will display as **Inactive**.
### Reactivating schedules
If you want to reactivate a schedule, follow these steps:
2. Find the schedule you want to reactivate, select **More Options** &gt; **Activate**. The schedule will display as **Active** state and will run according to its configuration.
## Deleting schedules
To delete a schedule, follow these steps:
2. Find the schedule you want to delete, select **More Options** &gt; **Delete**. The schedule has been permanently deleted and is no longer listed as a schedule.
## Result
The schedule is saved and the automated test execution runs at the configured time. You can view and manage all schedules under **Schedules** in the **Execution** section.
