# Cloning test sets
> Clone a test set in Test Manager, with options to retain documents, labels, and assigned test cases.
You can only clone one Test Set at a time.
1. Select **More Options** for the Test Set that you want to duplicate, and select **Clone**.
2. Rename the Test Set and choose the information you want to clone, such as:
   * **Documents**
   * **Labels**Test Cases assigned to the original Test Set (both statically and dynamically) are automatically linked to the clone. Custom field definitions, and custom field values are also cloned if they exist.
3. Select **Confirm** to start the cloning process. The clone is created in the background.
A clone of the Test Set is created with a different ID.
   ![Cloned test set created with different ID in Test Manager](https://dev-assets.cms.uipath.com/assets/images/test-manager/test-manager-docs-image-268326-0ec417c3-f3c0d6a2.webp)
## Result
A clone of the test set is created with a different ID and is listed on the **Test Sets** page.
