# Cloning test cases
> Clone a test case in Test Manager, with options to carry over requirement assignments, documents, and other attributes.
You can only clone one test case at a time.
1. Select **More Options** for the test case that you want to duplicate, and then **Clone**. The **Clone** panel appears.
2. You can rename the test case and select the information that you want to clone:
   1. **Assignment to requirements**
   2. **Documents**
   3. **Labels**
   Manual steps, custom field definitions, and custom field values are also cloned if they exist.
3. Select **Confirm** to clone the test case. The **Test case will be cloned in the background** message appears.
A clone of the test case is created, with a different Id.
![Cloned test case created with different ID in Test Manager](https://dev-assets.cms.uipath.com/assets/images/test-manager/test-manager-docs-image-130278-0d010aca-ea6f9804.webp)
:::note
* Automation information isn't cloned.
* Assignments to external requirements aren't cloned.
## Result
A clone of the test case is created with a different ID and is listed on the **Test Cases** page.
