# Automation project configuration
> Settings for configuring a default Orchestrator folder in Test Manager project automation settings, including role requirements and package selection.
Navigate to the **Automation** tab within your **Project Settings** to specify a default Orchestrator folder for your project. This allows you to execute test cases only from specific packages and versions found within the chosen folder.
## Roles and permissions
Only users assigned the roles of **Test Manager Administrator** at the tenant level or **Project Owner** at the project level have the ability to set the default Orchestrator folder.
## Assigning a default folder
To assign a default Orchestrator folder to your project, perform the following steps:
1. Select the **Default Folder** dropdown list.
2. Select your preferred Orchestrator folder.
3. Select **Save** to confirm your changes. The selected folder is displayed and will be used for all your test sets.
:::note
The **Default Folder** dropdown list only displays the Orchestrator folders to which you have access.
