# Assigning manual executions
> Assign one or multiple manual test case executions to a user and set a due date for completion.
Assign manual test case executions to a tester from the Execution section, regardless of how the execution was started.
## Prerequisites
To assign or unassign manual test case logs, you must have the **Change test case executions assignments** task permission in one of your roles. By default, this task permission is integrated in the **Test Manager** pre-defined role.
The user to whom you assign the test case must have permissions to execute tests.
## Steps
1. Go to the **Execution** section of your project.
2. Select the name of a test execution and open it.
   :::note
   Any test execution can be selected, regardless of its type. This is because the objective is to facilitate manual execution by the user, irrespective of the method used in its prior execution.
3. Assign the manual test case executions in one of the following ways:
   * To assign a single manual test case execution: select **More Options** for the desired test case, and then select **Assignment**.
   * To assign multiple manual test case executions: select the check boxes next to the desired manual test case keys, and then select **Assign**. The **Assignment** dialog box opens.
4. In the **Assignee** field, enter the username or email address of the user to which you want to assign the test cases.
5. In the **Set the due date** field, enter the date by which you want the user to run the test case. The format of the date is: Month/Day/Year. You can also use the date picker for this step.
6. Select **Assign** to complete your action.
   :::tip
   You can also change the assignment and due date from the header of the test case execution log.
   Figure 1. Overview of the **Assignment** dialog box
   ![Overview of the Assignment dialog box](https://dev-assets.cms.uipath.com/assets/images/test-manager/test-manager-overview-of-the-assignment-dialog-box-462274-08c9d45f-45fffcb5.webp)
## Result
The selected test case executions are assigned to the specified user with the given due date, and the user receives a notification if subscribed to these events.
