# About coded app projects
> Coded app project architecture in Studio Web, covering how Studio Web and your local IDE split responsibilities and which files matter at each stage.
A coded app project in Studio Web is a pro-code project that lives inside a solution. Studio Web owns the project's identity and its publish lifecycle. The app's source code is written in your own local project and pushed into Studio Web with the UiPath CLI.
## What Studio Web owns and what your IDE owns
| Concern | Owned by Studio Web | Owned by your local IDE |
| Project identity inside the solution | ✅ | — |
| `webAppManifest.json` (project type and configuration) | ✅ | — |
| Registering bindings from the pushed `bindings_v2.json` | ✅ | — |
| Solution-level publish and deploy | ✅ | — |
| Read-only view of the last pushed source | ✅ | — |
| Source-code authoring, framework choice, dependencies | — | ✅ |
| `bindings_v2.json` — declaring which Orchestrator resources the app uses | — | ✅ |
| Local dev server, previewing the running app, debugging | — | ✅ |
## Files that matter
### After initializing the project in Studio Web
Studio Web creates a single file:
| File | Purpose |
| `webAppManifest.json` | Describes the project's type (`Coded`) and configuration. Owned by Studio Web — you don't edit it directly. |
Example:
```json
  "type": "Coded",
  "solutionResourceSubType": "CodedAction",
  "config": {
    "isCompiled": true,
    "isActionApp": true
### In your local project (what you build and push)
Your local project is whatever your framework of choice produces. Studio Web does not require a specific folder structure; only what you push is stored.
If the app needs UiPath resources at runtime, a `bindings_v2.json` file at the root of what you push declares those resources. Studio Web reads this file on push and registers each declared resource — see [Bindings and runtime resources](https://docs.uipath.com/studio-web/automation-cloud/latest/user-guide/bindings-and-runtime-resources-for-coded-apps).
## Where to go next
Find out more about working with coded app projects:
* [Initializing a coded app project](https://docs.uipath.com/studio-web/automation-cloud/latest/user-guide/designing-coded-app-projects)
* [Working in your IDE](https://docs.uipath.com/studio-web/automation-cloud/latest/user-guide/local-setup-for-coded-app-projects)
* [Bindings and runtime resources](https://docs.uipath.com/studio-web/automation-cloud/latest/user-guide/bindings-and-runtime-resources-for-coded-apps)
* [Publishing and deploying coded app projects](https://docs.uipath.com/studio-web/automation-cloud/latest/user-guide/publishing-deploying-coded-app-projects)
