# January 2025
> January 2025 release notes for Studio Web in Automation Cloud.
## 29 January 2025
### New Date selector
Activities that use the **Date** selector to set a date in compatible activity fields no longer require you to also select the time. Fields that require both date and time will continue to ask for both values.
![Date selector](https://dev-assets.cms.uipath.com/assets/images/studio-web/studio-web-date-selector-515637-4a5ef4e1.webp)
### New flow for tabular controls and entities in Apps in Studio
You can now connect tabular controls such as the **Table, Edit Grid, Custom List, Dropdown,** and **Multiselect Dropdown** to your Data Service entities, as part of automation workflows in Web App projects.
Use the **Create workflow** option in the **Data source** field to add [Data Service-based activities](https://docs.uipath.com/activities/other/latest/workflow/about-the-dataservice-activities-pack) to your web app within Studio workflows. This allows you to create, query, edit, or delete records from your Data Service entities as a part of your automations.
For more details, refer to [Using tabular controls with Data Service entities in web app projects](https://docs.uipath.com/studio-web/automation-cloud/latest/user-guide/using-tabular-controls-with-data-service-entities-in-app-projects).
### Recent activities updates
The following categories of activities are now in general availability:
* [Mail](https://docs.uipath.com/activities/other/latest/productivity/smtp-imap-and-pop3)
* [SAP OData](https://docs.uipath.com/activities/other/latest/integration-service/uipath-sap-odata-activities)
The following categories of activities have received updates:
* [Mail](https://docs.uipath.com/activities/other/latest/productivity/release-notes-uipath-mail-activities) (v1.24.12)
* [Microsoft 365](https://docs.uipath.com/activities/other/latest/productivity/release-notes-microsoftoffice365-activities) (v2.8.23)
* [Google Workspace](https://docs.uipath.com/activities/other/latest/productivity/release-notes-uipath-gsuite-activities) (v2.8.23)
The following categories of activities are now available in preview:
* [Data Service](https://docs.uipath.com/activities/other/latest/workflow/data-service-activities)
* [Google Forms](https://docs.uipath.com/activities/other/latest/productivity/forms-activities)
## 21 January 2025
### New Custom List control
Web App projects now support the **Custom List** control, a dynamic template-based control which allows you to add other controls within its layout.
Learn how to use this control [in the Apps documentation](https://docs.uipath.com/apps/automation-cloud/latest/user-guide/custom-list).
