- Introduction
- Démarrage
- Gestion des projets et packages de solutions
- Gestion des déploiements de solutions
- Meilleures pratiques
Naviguer dans la barre latérale Déploiements
Deployments sidebar contents and management options for inspecting and acting on solution deployments in Automation Suite.
Vue d'ensemble (Overview)
The Deployments sidebar provides a contextual view of a solution's deployment directly from the Deployments tab. It lets you inspect deployment details and manage your deployment without leaving the Deployments page.
At the top of the sidebar, you can see the deployment's title, its version (whether it is the latest or if a newer version is available), its status (Pending, Failed, or Active), and a brief description, if available.
Below the header, you can see the activation status of the deployment, its folder path location (selectable, so you can navigate to the solution folder), its last operation, and when it was last performed.
Développer la barre latérale Déploiements
Pour développer la barre latérale Déploiements:
- Accédez à Orchestrator > Solutions.
- Sélectionnez l'onglet Déploiements .
- Dans la liste, sélectionnez le déploiement d'une solution.
La barre latérale Déploiements s'ouvre sur le côté droit de l'écran et reste dans le contexte pendant que vous parcourez les informations de déploiement.
If your deployment is successfully installed and activated, you can select Deployment details from the Deployment logs and navigate directly to the Deployments sidebar.
Gérer un déploiement à partir de la barre latérale
Depending on the state of your deployment, you may be able to take the following actions:
Regardless of a deployment's status or activation readiness, you can select Uninstall or Edit. If a deployment was uninstalled, you can also delete it.
| État du déploiement | Statut d’activation | Action disponible |
| Installation réussie | Actif (Active) | Select Go to folder to navigate to the solution's folder in Orchestrator. |
| Modification de la configuration - Brouillon | Actif (Active) | Select Continue if you were in the middle of changing your deployment's configuration. |
| Installation réussie | Nécessite une configuration afin d’être activé | Select Set up activation to configure your solution for activation readiness. |
| Installation réussie | Prêt à être activé | Sélectionnez Activer le déploiement. |
| Installation - En cours | S/O | Aucune action disponible. |
| Modification de la configuration - Réussite | Actif (Active) | Sélectionnez Modifier la version pour mettre à niveau votre configuration. |
Dans l’onglet Ressources , vous pouvez afficher la liste de tous les composants inclus dans votre solution, notamment les processus, les connexions, les déclencheurs, les ressources et les compartiments de stockage.
Naviguer dans l’onglet Historique
For each deployment, you can view details regarding its history and select Refresh to get the most recent view.
Si vous avez effectué plus de 20 opérations sur un déploiement, augmentez le nombre d'éléments affichés dans la table Historique.
| Colonne | Description |
| Version | La version de la solution déployée. |
| Dernière opération | L'opération la plus récente effectuée sur le déploiement, telle que l'installation, la désinstallation, la configuration de l'activation, la mise à niveau, la rétrogradation, la modification de la configuration ou la restauration. |
| État (Status) | Le statut actuel du déploiement. |
| Démarré (Started) | Le temps écoulé depuis le début du déploiement. |
| Auteur | Le nom d'utilisateur de l'utilisateur qui a effectué l'opération. |
