- Démarrage
- Comprendre UiPath Robot
- Assistant UiPath
- Prérequis d’installation
- Installing robots for unattended automations
- Configuring robots for unattended automations
- Connecting robots for unattended automations to Orchestrator
- Configuration de Windows Server pour des Robots haute densité
- Rediriger les Robots vers un serveur proxy
- Implementing authentication
- Adjusting registry settings for execution in minimized RDP windows
- Using network locations
- Configurer des Robots Linux
- Configuration de la vérification de la signature des paquets
- Configurer des dossiers de package et des chemins d’accès réseau
- Configurer des flux d’activité
- Deploying unattended automations
- Installing robots for attended automations
- Configuring robots for attended automations
- Intégrations
- Résolution des problèmes
Licences de robot
A licensing process most commonly starts with activating your Orchestrator license. Afterward, you license your Robot by connecting it to Orchestrator or from the Command Line, using the LicenseTool utility.
When your Robot is not connected to Orchestrator, you can activate the license with the help of the Command Prompt.
To execute attended automations, you need to allocate one or more user licenses to your robots.
For this, you need to have a robot account in Orchestrator. Once the user license is assigned to a specific username, that user can run one or more attended automations on the computer under their username.
The following user licenses are available for attended automations:
Assisté (Attended)
Développement citoyen
Automation Developer
To execute unattended automations, you need to allocate one or more robot licenses (or runtimes) to your robots, specifically to the machine that hosts your robots. The number of runtimes assigned to a machine represents the execution capacity. For example, with one runtime, you can execute only one unattended automation at a time. With five runtimes, you can execute up to five unattended automations at the same time, on the same host machine.
Depending on the type of automation, allocate the runtimes as follows:
For foreground automations - allocate one runtime, as this type of automations are executed one at a time.
For background automations - Windows machines require one runtime, as they execute one background automation at a time. Windows-Server machines can execute several background automations simultaneously, which represents a concurrent execution.
For concurrent executions - allocate more than one runtime. The number of allocated runtimes determines how many automations you can execute simultaneously on the same machine.
The following runtimes are available for unattended automations:
Unattended (Production)
Hors production (NonProduction)
Test
UiPath.LicenseTool.exe
is a command-line utility which enables you to activate your machine online or offline, and update your license information.
The LicenseTool utility activates your license locally, which requires you to select the Standalone license type when creating a robot in Orchestrator.
The following sections provide the most common commands for online, offline, and generic licensing operations. The commands need to be initiated in the same folder where the utility resides, which be default is the "C:\Program Files\UiPath\Studio" folder.
Les commandes suivantes nécessitent une connexion Internet active pour pouvoir traiter votre demande.
Activer (Activate)
activate
permet d'activer une licence en ligne via un code de licence existant. Les paramètres suivants sont pris en charge :
Paramètre |
Description |
Priorité (Priority) |
-l , --LicenseCode |
Code de licence requis pour l'activation. |
Obligatoire |
-u , --ProxyUrl |
The URL used for the proxy connection (such as
http://your.proxy.server.com ).
Facultatif |
-p , --ProxyPort |
Numéro de port de la connexion du proxy. |
Facultatif. Obligatoire si le paramètre
-u est utilisé.
-s , --ProxyUser |
Nom d'utilisateur associé à votre connexion de proxy. |
-u est utilisé.
-w , --ProxyPassword |
Mot de passe de l'utilisateur associé à la connexion de votre proxy. |
-u est utilisé.
C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe activate -l 1234-1234-2194-5598
License registration state: ActiveLicense
License successfully activated!
L'activation en ligne peut également être effectuée à partir de Studio.
Mettre à jour (Update)
update
est utilisée pour mettre à jour une licence existante en ligne. Les paramètres suivants sont pris en charge :
Paramètre |
Description |
-u , --ProxyUrl |
Facultatif |
-p , --ProxyPort |
-u est utilisé.
-s , --ProxyUser |
-u est utilisé.
-u est utilisé.
C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe update
License successfully updated!
Désactiver
deactivate
permet de désactiver une licence locale. De cette façon, la licence devient disponible pour l'activation sur un autre ordinateur. Les paramètres suivants sont pris en charge :
Paramètre |
Description |
-u , --ProxyUrl |
Facultatif |
-p , --ProxyPort |
-u est utilisé.
-s , --ProxyUser |
-u est utilisé.
-u est utilisé.
C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe deactivate
License registration state: NoLicenseAvailable
License successfully deactivated!
Demande d'activation
activation-request
est utilisée pour générer un jeton d'activation à partir de votre code de licence. Le jeton généré doit être utilisé sur le portail d'activation pour générer le fichier de licence correspondant. Les paramètres suivants sont pris en charge:
Paramètre |
Description |
Obligatoire |
o , --FileName |
Écrit des informations de licence dans un fichier. Si ce paramètre n'est pas spécifié, les informations de licence s'affichent dans la fenêtre de l'invite de commande. |
Facultatif |
C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe activation-request -l 1234-2303-2194-5598
Activation Token: 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
Go to https://activate.uipath.com and paste the activation token in the dialogue box to generate the license file for offline activation.
Activer hors ligne
activate-offline
est utilisée pour activer une licence offline. Il utilise le fichier de licontenu_fichiers_indexablesence généré par le Activation Portal partir du jeton d'activation fourni généré par la commande activation-request
Paramètre |
Description |
-f , --LicenseFile |
Chemin d'accès au fichier de licence obtenu à partir du portail d'activation. |
1 Obligatoire |
-i , --LicenseContent |
Contenu du fichier de licence reçu après avoir utilisé l'opération
Activation-Request .
1 Obligatoire |
1
- Vous ne pouvez utiliser que les paramètres-f
ou-i
avec l'opérationactivate-offline
. Ils ne sont pas tous deux pris en charge en même temps.C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe activate-offline -f c:\Downloads\license.txt License registration state: ActiveLicense License successfully activated!
L’activation hors ligne peut également être effectuée à partir de Studio.
Demande de mise à jour
update-request
est utilisée pour générer un jeton de mise à jour pour votre licence. Le jeton de mise à jour doit être utilisé sur le portail d'activation pour générer le fichier de licence correspondant. Les paramètres suivants sont pris en charge :
Paramètre |
Description |
-o , --FileName |
Facultatif |
C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe update-request
Update Token: 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
Go to https://activate.uipath.com and paste the update token in the dialogue box to generate the license file for offline update.
Mise à jour-hors ligne
update-offline
est utilisée pour mettre à jour une licence offline. Il utilise le fichier généré par le Activation Portal de la mise à jour fournie jeton généré par la commande update-request
Paramètre |
Description |
1 Obligatoire |
Update-Request .
1 Obligatoire |
1
ou-i
avec l'opérationupdate-offline
. Ils ne sont pas tous deux pris en charge en même temps.C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe update-offline -f c:\Downloads\license-update.txt License registration state: ActiveLicense License successfully updated!
Demande de désactivation
deactivation-request
permet de désactiver une licence locale hors ligne et de générer un jeton de désactivation. La licence est immédiatement désactivée sur l'ordinateur local et une autre peut être activée, si nécessaire. Le jeton de désactivation généré doit être utilisé sur le Portail d'activation pour désactiver la licence. Notez que la licence qui a été désactivée hors ligne à l'aide de cette commande ne peut pas être réutilisée tant qu'elle n'a pas été libérée. Les paramètres suivants sont pris en charge :
Paramètre |
Description |
-o , --FileName |
Facultatif |
C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe deactivation-request
Deactivation Token: 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
License successfully deactivated locally!
To release the license on the sever side and use it on another machine, go to https://activate.uipath.com and paste the deactivation request certificate as text in the <code>Deactivate your licence</code> tab.
contient également quelques commandes génériques. Elles fournissent des informations sur votre licence et peuvent vous aider à vous familiariser avec les commandes et les paramètres pris en charge.
Commande |
Description |
Affiche des informations sur la licence, telles que :
Affiche des informations sur toutes les commandes et tous les paramètres pris en charge. |
Affiche la version de l'utilitaire
UiPath.LicenseTool.exe .
