# Installing with UiPathRobot.msi
> Install Robot and Assistant for attended automation using the UiPathRobot.msi installer with Quick or Custom setup options.
Running the `UiPathRobot.msi` installs only Robot and Assistant.
First, download the installer from the [Product Downloads](https://customerportal.uipath.com/product-downloads) section in Customer Portal. Look for the following entry:
* For Enterprise versions—UiPath Robot & Assistant &lt;version_number&gt;
Once the download is complete, continue with the following steps.
1. Launch the installer.
2. Read and accept the [License Agreement](https://www.uipath.com/developers/all-editions/license-agreement), which includes the UiPath terms of use for activity packages and their dependencies.
3. Select the type of installation: **Quick** or **Custom**.
   If you select **Quick**, continue the installation by selecting **Install**.
   For **Custom**, continue by selecting **Configure** and following the remaining steps.
4. In the **Choose and installation package** section, decide who should be able to use the attended installation:
   * **Install for me only: Attended** - Installs Robot and Assistant to run attended automations. Your custom configuration applies to the current user profile. No administrator privileges needed. Follow step 5 for advanced settings.
   * **Install for all users: Attended** - Installs Robot and Assistant to run attended automations. Your custom configuration applies to all users on the machine. Needs administrator privileges. Follow step 6 for advanced settings.
5. To customize the **Install for me only: Attended** installation, select **Advanced Settings**. Then customize the following settings:
   1. For **Installation Package**:
      * **Orchestrator URL** - The URL of the Orchestrator instance to connect to using Interactive Sign-In. This value is saved in the `uipath.config` file.
      * **Automatically sign in** - When your environment is configured to use [SSO with Azure Active Directory](https://docs.uipath.com/automation-cloud/automation-cloud/latest/admin-guide/azure-ad-integration), select this option to enable automatic authentication for your account.
   2. For **Extensions**, select the extensions you want to install. By default, the UiPath JavaScript Robot Add-on, Chrome, and Edge Chromium extensions are installed.
      * **Packages configuration** - Select the **Disable Online Feeds** option if you want to disable the Official and Marketplace online feeds for activity packages. Recommended for offline environments.
   3. For **Security**, select the security options for your installation:
      * **Enforce Signed Execution** - Instructs the Robot to execute signed packages exclusively.
      * **Disable Secured XAMLs** - Disables security of XAML files for Robots installed as a Windows service. Unsecured XAML files allow users to read and modify the process files and logic.
      * **Disable Telemetry** - Disables the collection of anonymous usage data for Studio and Robot.
6. To customize the **Install for all users: Attended** installation, select **Advanced Settings**. Then customize the following settings:
      * **Installation Path** - The destination folder for installation, other than the default one in `%ProgramFiles%`.
      * **License Code (optional)** - The key for your standalone trial or enterprise license. Without a key during a the standalone trial setup, Studio prompts for it upon its first launch.
      * **Automatically Starts Assistant with Windows** - Option enabled by default, launches Assistant at Windows startup.
      * **Default download location** - The download location for activity packages. Default location is `%userprofile%.nuget\packages`.
7. Select **Install**.
