# Installing the Z_XTRACT_IS_TABLE Function Module on Your SAP System
> Z_XTRACT_IS_TABLE Function Module requirements and installation steps for enabling native SAP extraction in standalone Process Mining.
## Introduction
To use the native SAP extraction from **UiPath Process Mining**, you must add the `Z_XTRACT_IS_TABLE` Function module to your SAP system.
:::note
When setting up a native SAP extraction the SAP `Z_XTRACT_IS_TABLE` Function Module is required. If, for example, the Function Module is renamed in your SAP system, you can specify the correct name in the (optional) `FunctionModule` parameter in the SAP connection string.
### Prerequisite
To be able to install the Custom Function Module on your SAP system you must have the credentials of an SAP user with a development key.
## Adding a New Function Group
:::note
It is recommended to add a new Function group to add the function module.
Follow these steps to add a new Function group.
 <colgroup>
  <col/>
  <col/>
 </colgroup>
     Step
     Action
     1
     Open the SAP GUI.
     2
    Enter <code>SE37</code> in the command field in the top left.
     3
     Go to the Goto menu and select Function group -&gt; Create group .
     4
     Enter a name for the Function group. Note: the name must start with <code>Z</code> , for example <code>Z_PM_DATA_EXTRACTION</code> .
     5
     Enter a description for the Function group in the Short Text field, for example ProcessMining Data Extraction .
     6
     Click on Save .
### Activating the Function Group
Follow these steps to activate the Function group.
| Step | Action |
| 1 | Select **Function Group**. |
| 2 | Search for the Function group you created, for example `PM_DATA_EXTRACTION`. |
| 3 | Right-click on the top object of the Function group and select **Activate it** from the context menu. |
## Adding the Function Module
Once the Function group is created, you can add the Function module from the SE37 GUI window.
Follow these steps to install the Z_XTRACT_IS_TABLE Function module.
 <colgroup>
  <col/>
  <col/>
 </colgroup>
     Step
     Action
     1
    Enter <code>Z_XTRACT_IS_TABLE</code> in the Function Module field and click on Create .
     2
     Go to the Attributes tab and select the Remote-Enabled Module option in the Processing Type options list.
     3
     Go to the Import tab and define the import parameters as listed below. Note: you might get a warning that the <code>LIKE</code> operator is obsolete. You can ignore the warning and go through the list. Click ENTER to acknowledge that you still want to use it. Once you went through the entire list the code is accepted.
     4
     Go to the Tables tab and define the tables parameters as listed below. Note: you might get a warning that the <code>LIKE</code> operator is obsolete. You can ignore the warning and go through the list. Click ENTER to acknowledge that you still want to use it. Once you went through the entire list the code is accepted.
     5
     Go to the Exceptions tab to define the exceptions as listed below.
     6
    Go to the Source code tab and enter the <code>ABAP</code> code for the <code>Z_XTRACT_IS_TABLE</code> . Note: you can copy and paste the code displayed below.
     7
     Save the Function module and activate it.
### Import Parameters
See illustration below for an overview of the import parameters to be defined in the **Import** tab.
![docs image](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-docs-image-54440-66d5dd90-f6c2a7c8.webp)
### Tables Parameters
See illustration below for an overview of the tables parameters to be defined in the **Tables** tab.
![docs image](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-docs-image-57993-2e286a64-e0f0018c.webp)
### Exceptions
See illustration below for an overview of the Exceptions to be defined in the **Exceptions** tab.
![docs image](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-docs-image-53728-bb26bde9-f25f763e.webp)
### ABAP Code
See code text below for the ABAP code to be pasted in the **Source code** tab.
FUNCTION Z_XTRACT_IS_TABLE.
*"*"Lokale Schnittstelle:
*"  IMPORTING
*"     VALUE(QUERY_TABLE) LIKE  DD02L-TABNAME
*"     VALUE(DELIMITER) LIKE  SONV-FLAG DEFAULT SPACE
*"     VALUE(NO_DATA) LIKE  SONV-FLAG DEFAULT SPACE
*"    VALUE(ROWSKIPS) LIKE  SOID-ACCNT DEFAULT 0
*"     VALUE(ROWCOUNT) LIKE  SOID-ACCNT DEFAULT 0
*"  TABLES
*"      OPTIONS STRUCTURE  RFC_DB_OPT
*"      FIELDS STRUCTURE  RFC_DB_FLD
*"     DATA STRUCTURE  CHAR8000
*"  EXCEPTIONS
*"      TABLE_NOT_AVAILABLE
*"      TABLE_WITHOUT_DATA
*"     OPTION_NOT_VALID
*"     FIELD_NOT_VALID
*"     NOT_AUTHORIZED
*"      DATA_BUFFER_EXCEEDED
CALL FUNCTION 'VIEW_AUTHORITY_CHECK'
     EXPORTING
          VIEW_ACTION                    = 'S'
          VIEW_NAME                      = QUERY_TABLE
     EXCEPTIONS
          NO_AUTHORITY                   = 2
          NO_CLIENTINDEPENDENT_AUTHORITY = 2
          NO_LINEDEPENDENT_AUTHORITY     = 2
          OTHERS                         = 1.
IF SY-SUBRC = 2.
  RAISE NOT_AUTHORIZED.
ELSEIF SY-SUBRC = 1.
  RAISE TABLE_NOT_AVAILABLE.
ENDIF.
*  find out about the structure of QUERY_TABLE
DATA BEGIN OF TABLE_STRUCTURE OCCURS 10.
        INCLUDE STRUCTURE DFIES.
DATA END OF TABLE_STRUCTURE.
"DATA TABLE_HEADER LIKE X030L.
DATA TABLE_TYPE TYPE DD02V-TABCLASS.
CALL FUNCTION 'DDIF_FIELDINFO_GET'
  EXPORTING
    TABNAME              = QUERY_TABLE
*   FIELDNAME            = ' '
*   LANGU                = SY-LANGU
*   LFIELDNAME           = ' '
*   ALL_TYPES            = ' '
*   GROUP_NAMES          = ' '
  IMPORTING
*   X030L_WA             =
    DDOBJTYPE            = TABLE_TYPE
*   DFIES_WA             =
*   LINES_DESCR          =
  TABLES
    DFIES_TAB            = TABLE_STRUCTURE
*   FIXED_VALUES         =
  EXCEPTIONS
    NOT_FOUND            = 1
    INTERNAL_ERROR       = 2
    OTHERS               = 3
IF SY-SUBRC <> 0.
ENDIF.
IF TABLE_TYPE = 'INTTAB'.
  RAISE TABLE_WITHOUT_DATA.
ENDIF.
*  isolate first field of DATA as output field
*  (i.e. allow for changes to structure DATA!)
DATA LINE_LENGTH TYPE I.
FIELD-SYMBOLS <D>.
ASSIGN COMPONENT 0 OF STRUCTURE DATA TO <D>.
* If this line leads to a syntax error
* please just delete the 'in character mode'
DESCRIBE FIELD <D> LENGTH LINE_LENGTH in character mode.
*  if FIELDS are not specified, read all available fields
DATA NUMBER_OF_FIELDS TYPE I.
DESCRIBE TABLE FIELDS LINES NUMBER_OF_FIELDS.
IF NUMBER_OF_FIELDS = 0.
  LOOP AT TABLE_STRUCTURE.
    MOVE TABLE_STRUCTURE-FIELDNAME TO FIELDS-FIELDNAME.
    APPEND FIELDS.
  ENDLOOP.
ENDIF.
*  for each field which has to be read, copy structure information
*  into tables FIELDS_INT (internal use) and FIELDS (output)
DATA: BEGIN OF FIELDS_INT OCCURS 10,
        FIELDNAME  LIKE TABLE_STRUCTURE-FIELDNAME,
        TYPE       LIKE TABLE_STRUCTURE-INTTYPE,
        DECIMALS   LIKE TABLE_STRUCTURE-DECIMALS,
        LENGTH_SRC LIKE TABLE_STRUCTURE-INTLEN,
        LENGTH_DST LIKE TABLE_STRUCTURE-LENG,
        OFFSET_SRC LIKE TABLE_STRUCTURE-OFFSET,
        OFFSET_DST LIKE TABLE_STRUCTURE-OFFSET,
      END OF FIELDS_INT,
      LINE_CURSOR TYPE I.
LINE_CURSOR = 0.
*  for each field which has to be read ...
LOOP AT FIELDS.
  READ TABLE TABLE_STRUCTURE WITH KEY FIELDNAME = FIELDS-FIELDNAME.
  IF SY-SUBRC NE 0.
    RAISE FIELD_NOT_VALID.
  ENDIF.
* compute the place for field contents in DATA rows:
* if not first field in row, allow space for delimiter
  IF LINE_CURSOR <> 0.
    IF NO_DATA EQ SPACE AND DELIMITER NE SPACE.
      MOVE DELIMITER TO DATA+LINE_CURSOR.
    ENDIF.
    LINE_CURSOR = LINE_CURSOR + STRLEN( DELIMITER ).
  ENDIF.
* ... copy structure information into tables FIELDS_INT
* (which is used internally during SELECT) ...
  FIELDS_INT-FIELDNAME  = TABLE_STRUCTURE-FIELDNAME.
  FIELDS_INT-LENGTH_SRC = TABLE_STRUCTURE-INTLEN.
*  FIELDS_INT-LENGTH_DST = TABLE_STRUCTURE-LENG.
* modified by Theobald, 2007-11-20
  FIELDS_INT-LENGTH_DST = TABLE_STRUCTURE-OUTPUTLEN.
  FIELDS_INT-OFFSET_SRC = TABLE_STRUCTURE-OFFSET.
  FIELDS_INT-OFFSET_DST = LINE_CURSOR.
  FIELDS_INT-TYPE       = TABLE_STRUCTURE-INTTYPE.
  FIELDS_INT-DECIMALS   = TABLE_STRUCTURE-DECIMALS.
* compute the place for contents of next field in DATA rows
*  LINE_CURSOR = LINE_CURSOR + TABLE_STRUCTURE-LENG.
LINE_CURSOR = LINE_CURSOR + TABLE_STRUCTURE-OUTPUTLEN.
  IF LINE_CURSOR > LINE_LENGTH AND NO_DATA EQ SPACE.
    RAISE DATA_BUFFER_EXCEEDED.
  ENDIF.
  APPEND FIELDS_INT.
* ... and into table FIELDS (which is output to the caller)
  FIELDS-FIELDTEXT = TABLE_STRUCTURE-FIELDTEXT.
  FIELDS-TYPE      = TABLE_STRUCTURE-INTTYPE.
  FIELDS-LENGTH    = FIELDS_INT-LENGTH_DST.
  FIELDS-OFFSET    = FIELDS_INT-OFFSET_DST.
  MODIFY FIELDS.
ENDLOOP.
* end of loop at FIELDS
*  read data from the database and copy relevant portions into DATA
* output data only if NO_DATA equals space (otherwise the structure
* information in FIELDS is the only result of the module)
IF NO_DATA EQ SPACE.
DATA: BEGIN OF WORK, BUFFER(30000), F TYPE F, END OF WORK.
FIELD-SYMBOLS: <WA> TYPE ANY, <COMP> TYPE ANY.
ASSIGN WORK TO <WA> CASTING TYPE (QUERY_TABLE).
IF ROWCOUNT > 0.
  ROWCOUNT = ROWCOUNT + ROWSKIPS.
ENDIF.
  SELECT * FROM (QUERY_TABLE) INTO <WA> WHERE (OPTIONS).
    IF SY-DBCNT GT ROWSKIPS.
*   copy all relevant fields into DATA (output) table
      LOOP AT FIELDS_INT.
        IF FIELDS_INT-TYPE = 'P'.
        ASSIGN COMPONENT FIELDS_INT-FIELDNAME
            OF STRUCTURE <WA> TO <COMP>
            TYPE     FIELDS_INT-TYPE
            DECIMALS FIELDS_INT-DECIMALS.
        ELSE.
            TYPE     FIELDS_INT-TYPE.
        ENDIF.
        MOVE <COMP> TO
            <D>+FIELDS_INT-OFFSET_DST(FIELDS_INT-LENGTH_DST).
      ENDLOOP.
*   end of loop at FIELDS_INT
      APPEND DATA.
      IF ROWCOUNT > 0 AND SY-DBCNT GE ROWCOUNT. EXIT. ENDIF.
    ENDIF.
  ENDSELECT.
ENDIF.
ENDFUNCTION.
## Checking and Activating the Function Module
After you pasted the ABAP code it is recommend to check your code for syntax errors before you activate the Function module.
### Checking the Function Module
Follow this step to check the ABAP code.
| Step | Action |
| 1 | Press `CTRL+F2` in the SAP **Source code** tab. |
If there are no errors, you can activate the Function module.
### Activating the Function Module
Follow these steps to activate the Function module.
| Step | Action |
| 1 | Enter `SE80` in the command field in the top left. |
| 2 | Select **Function Module**. |
| 3 | Search for `Z_XTRACT_IS_TABLE`. |
| 4 | Right-click on the top object of `Z_XTRACT_IS_TABLE` and select **Activate it** from the context menu. |
## Connecting to the SAP Datasource From UiPath Process Mining
At this point it is possible to extract data from the SAP system using the native SAP connection. You can connect to the SAP datasource by creating a new input table using an SAP connection string table and defining a query to extract the data. See illustration below.
![docs image](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-docs-image-54028-a06ec704-3e9a98e5.webp)
