# Creating dashboards
> Add new empty dashboards to a process app menu using the dashboard editor on Automation Suite.
## Introduction
The dashboard editor enables you to create new dashboards and add these to your process app.
## Adding a new dashboard
Follow these steps to add a new empty dashboard to the menu.
1. Select ![Add dashboard icon](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-add-files-icon-325413-a638fff0-6fc688c5.webp)**Add dashboard** next to the process app name.
2. Select **Add dashboard** from the context menu.
A new dashboard labeled **New dashboard** is added to the menu.
3. In the **Select a layout** panel, select a layout for your dashboard.
   ![Select a layout panel.](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-select-a-layout-panel-15121-1e36a7a9-1c84068e.webp)
When you select a layout for your dashboard, empty tiles are created based on the selected layout.
4. Enter a name for the new dashboard in the **Dashboard name** field.
5. Select the KPIs you want to be displayed at the top of the new dashboard.
6. If desired, add dashboard level filters.
7. Add the charts to the dashboards.
Check out [Dashboards](https://docs.uipath.com/process-mining/automation-suite/2023.10/user-guide/dashboards#dashboards) and [Charts](https://docs.uipath.com/process-mining/automation-suite/2023.10/user-guide/charts#charts) for more information.
## Selecting a different layout for the dashboard
You can select a different layout for the dashboard you created. Follow these steps to select a different layout for the dashboard.
1. Select the dashboard for which you want to select a different layout.
2. Select the **Change layout** button in the **Edit dashboard** panel.
The different layout options are displayed and the current layout is highlighted.
3. Select the new layout for your dashboard.
   :::note
   Only the layout options that are applicable for the current available charts on the dashboard are enabled. You can either select a different layout, or remove one or more charts before selecting a different layout.
## Hiding or showing dashboards
If you are working on a dashboard and you do not want to show the dashboard in the published process app (yet), you can hide the dashboard.
Follow these steps to hide a dashboard from a published process app.
1. Select the dashboard that you want to hide.
2. Select the **Hide dashboard in app** icon in the **Edit dashboard** panel.
   ![Hide dashboard in app icon.](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-hide-dashboard-in-app-icon-14729-bcc489b2-1e644515.webp)
In the menu at the left it is indicated that the dashboard will not be visible in the published process app.
   ![Inidication that the dashboard will not be visible in the published process app.](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-inidication-that-the-dashboard-will-not-be-visible-in-the-published-process-app-15065-7bede7c7-df5d93ec.webp)
:::note
The **Hide dashboard from app** icon is a toggle. You can click on it again to make the dashboard visible.
## Removing a dashboard
Follow these steps to remove a dashboard from the menu.
1. Right click on the dashboard in the menu on the left and select **Remove dashboard** from the context menu.
You can also click on the dashboard in the menu to select it, and click on the ![](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-remove-tab-408929-05500a03-d61cdc60.webp)**Remove dashboard** icon in the **Edit dashboard** panel at the right.
The **Remove dashboard** is not available when there is only one dashboard.
:::note
The dashboard is removed from the menu without a notification message. When you remove a dashboard, all the charts on the dashboard are also removed.
