# Deployment and Configuration Considerations
> Security considerations for user and robot permissions when configuring Orchestrator deployments.
## User and Robot Permissions
There are two potential threats to guard against when configuring the user and robot permissions in Orchestrator: a malicious user or a malicious developer.
The authentication between Orchestrator and Robots is based on a shared key accessible only by the Administrator on the robot machine. If the machine user has administrative rights and can access that key, they would then be able to impersonate other robots when making calls to Orchestrator.
To mitigate the risks and potential impact from a malicious user, follow these guidelines:
* On machines configured for attended automation, ensure that the users on that machine do not have administrative rights.
* Limit robot permissions to the minimum required to execute the particular automation(s).
* In modern folders, disable robot creation for those users with administrator or other high-privilege roles in Orchestrator.
A malicious developer could deploy a process that, when executed by a user with high-level permissions in Orchestrator, grants that developer unwanted access or steals data.
To mitigate the risks and potential impact from a malicious developer, follow these guidelines:
* Maintain control and validation over any packages being deployed in Orchestrator.
* Audit automations prior to deployment to production (i.e., code review, virus scan, etc.).
## Password Policy
The default password policy states that all user passwords should contain at least 8 characters and at least one letter and a digit. This can be changed and made more complex in the **Settings** page, on the **Security** tab. For more information, see the [Settings Description](https://docs.uipath.com/orchestrator/standalone/2022.10/user-guide/robot-security-tab) topic.
## Encrypting the UiPath.Orchestrator.dll.config File
Encrypt the `SecureAppSettings` section of the `UiPath.Orchestrator.dll.config` file. To see how this can be done, please see [Encrypting UiPath.Orchestrator.dll.config Sections](https://docs.uipath.com/orchestrator/standalone/2023.10/installation-guide/orchestrator-encrypting-uipathorchestratordllconfig#encrypting-uipathorchestratordllconfig-sections).
## Disabling the Auto-complete Feature in Your Browser
The auto-complete feature available in most web browsers is not completely safe. To ensure that nobody can discover your Orchestrator login password, we recommend that you disable the aforementioned functionality in your preferred browser.
If you are using Internet Explorer 11:
1. In Internet Explorer, Select **Tools &gt; Internet Options**. The **Internet Options** window is displayed.
2. In the **Content** tab, select **Settings**. The **AutoComplete Settings** window is displayed.
3. Clear the **User names and passwords on forms** checkbox.
4. Select **OK**. Your settings are saved.
## Changing the Default System Admin Password
Change the default system administrator password (that was communicated to you by our team). You can do this by editing the user profile information. For more information, see [Managing tenants](https://docs.uipath.com/orchestrator/standalone/2022.10/user-guide/about-the-tenant-context).
## Not Selecting the Remember Me Checkbox
When you first log in to Orchestrator, do not select the **Remember Me** password. This helps you log out of the current session every time.
## Using Trusted SSL Certificates
While enforcing an HTTPS connection is important, it is just as important to have an SSL certificate from a trusted provider.
Additionally, you can remove the HTTP binding:
1. Open IIS.
2. In the **Connections** panel, navigate to the **Sites** folder.
3. Select the Orchestrator site. The **Actions** panel is updated accordingly.
4. Select **Bindings**. The **Site Bindings** window is displayed.
5. Select the **HTTP** binding and then **Remove**. The **HTTP** binding has been deleted.
## Adding Cache-Control
We recommend adding security caching directives to hide sensitive information that may be displayed in HTTP headers. Ideally, all responses should return the following HTTP headers:
Cache-control: no-store, no-cache, must-revalidate,private,s-maxage=0
Pragma: no-cache
To add these headers, just add them to the `web.config` file, in the `customHeaders` section, in the following format:
<add name="Cache-control" value="s-maxage=0"/>
