# Integrating credential stores
> The Central Credential Provider (CCP) is the agentless AAM method used to integrate with CyberArk allowing UiPath® to securely retrieve credentials from a vault without deploying an agent on the server. A client certificate is necessary to ensure secure retrieval of the credential.
## CyberArk® CCP integration
Before you can begin to use CyberArk® CCP credential stores in Orchestrator, you must first set up the corresponding application and safe settings in the CyberArk® PVWA (Password Vault Web Access) interface.
### Prerequisites
* A network that allows for interconnectivity between the Orchestrator service and the CyberArk server.
* CyberArk® Central Credential Provider must be installed on a machine that allows HTTP connections.
* CyberArk® Enterprise Password Vault
For more information about installing and configuring CyberArk® applications, please visit their [official page](https://www.cyberark.com/resources/).
### Configuring the integration
From the CyberArk® PVWA, you must perform the following steps:
1. [Create an application for your Orchestrator instance and add client certificates](integrating-credential-stores.md#cyberark-ccp-integration);
2. [Create a Safe and add members to it to ensure proper permissions](integrating-credential-stores.md#cyberark-ccp-integration).
#### Creating an Orchestrator application
1. In CyberArk®’s PVWA, log in with a user with permissions to manage applications (it requires Manage Users authorization).
2. In the **Applications** tab, click **Add Application**. The **Add Application** window is displayed.
   Figure 1. Add Application window
   ![Screenshot of the Add Application window](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-226787-2be0a992.webp)
3. On the **Add Application** window, specify the following information:
   * **Name** field - a custom name for the application, such as Orchestrator.
   * **Description** - a short description to help you specify the purpose of the new application.
   * **Location** - the path of the application within the Vault hierarchy. If a location is not specified, the application is added in the same location as the user who is creating this application.
4. Select **Add**. The application is added, and its details are displayed on the **Application Details** page.
5. Select the **Allow extended authentication restrictions** checkbox.
   **Supported authentication method**:
   * Allowed machines
   * OS User
   * Client Certificates - the client certificate used for the CyberArk authentication should be at least 2048 bits
6. Configure the authentication method. For example, in the **Authentication** tab, select **Add** &gt; **Certificate Serial Number**, and add the unique identifier of the client certificate, used to authenticate the requesting application against CCP.
   Figure 2. Certificate Serial Number
   ![Screenshot of the certificate serial number](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-227187-f58cdc30.webp)
#### Creating an Orchestrator safe
Safes are required to help you better manage your accounts. Also, you can add safe members to ensure proper authorization. CyberArk® recommends adding a **credential provider** (a user with full rights over the credentials can add and manage them) and the previously created application as safe members. The latter enables Orchestrator to find and retrieve the passwords stored in the safe.
1. In the **Policies** tab, under the **Access Control (Safes)** section, click **Add Safe**. The **Add Safe** page is displayed.
   Figure 3. Add Safe page
   ![Screenshot of the Add Safe page](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-232053-d3f4f04e.webp)
2. Fill in the **Safe Name** field and **Description** fields.
3. Click **Save**. The **Safe Details** window is displayed.
   Figure 4. Safe Details window
   ![Screenshot of the Safe Details window](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-233175-2e75521a.webp)
4. In the **Members** section, click **Add Member**. The **Add Safe Member** window is displayed.
   Figure 5. Members window
   ![Screenshot of the Members window](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-231210-0d8882d5.webp)
5. Search for the previously created application (steps 2-6), and select the following permissions for it:
   * **View Safe Members**
   * **Retrieve accounts**
   * **List accounts**
   * **Access Safe without Confirmation** - Only if you are using a dual control environment and a v7.2 or lower PIM-PSM.
     If you install multiple **credential providers** for this integration, it is recommended to create a group for them and add the group to the Safe once with the above authorization.
     Figure 6. Add Safe Member window
     ![Screenshot of the Add Safe Member window](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-232161-a4dc421c.webp)
6. Click **Add**. Your integration is complete, and you can begin provisioning CyberArk® credential stores in Orchestrator. For details on storing Robot credentials, see [here](storing-credentials-in-cyberark.md).
## CyberArk® AAM alternative
:::important
We do not recommend this solution, and we advise that it only be used as a temporary workaround while migrating to CyberArk® CCP.
CyberArk® AAM is not supported as an out-of-the-box solution, but we do offer an alternative: the Orchestrator Credentials Proxy. This tool allows you to connect Orchestrator and the credential store of your choice through the proxy, instead of directly, thus adding an extra layer of security.
The Orchestrator Credentials Proxy was created for cloud scenarios, where you may need to develop and deploy your own credential store plugins. It can, however, also be used in on-premises setups, such as Automation Suite. This is what you need to do:
1. Install the proxy on the Windows machine where your CyberArk® AAM client is configured. You can find details in the **[Orchestrator Credentials Proxy](https://docs.uipath.com/orchestrator/automation-cloud/latest/user-guide/orchestrator-credentials-proxy-installation#installation)** section.
2. Add the `Features.CredentialStoreHost.Enabled` parameter to the `orchestrator-customconfig` config map and set it to `true`. You can find details in the **[Preparing Orchestrator](https://docs.uipath.com/automation-suite/automation-suite/2023.4/installation-guide/configuring-appsettings)** section of the Automation Suite guide.
3. Set up the proxy by following the instructions outlined in the **[Managing credential proxies](https://docs.uipath.com/orchestrator/automation-cloud/latest/user-guide/managing-credential-store-proxies)** section.
## Azure Key Vault integration
Azure Key Vault is a plugin you can use as a credential store with Orchestrator.
There are two plugins included:
* **Azure Key Vault** – a read-write plugin (secrets are created through Orchestrator)
* **Azure Key Vault (read-only)** – a read-only plugin (you must provision the secrets in the vault directly)
### Prerequisites
* The Key Vault plugin is set in your Orchestrator `UiPath.Orchestrator.dll.config` file as described in the [Password Vault](https://docs.uipath.com/orchestrator/automation-suite/2023.4/installation-guide/uipath-orchestrator-dll-config#password-vault) section.
* Create the Key Vault to be used with Orchestrator in your Azure account. See Microsoft's official documentation [here](https://docs.microsoft.com/en-us/azure/key-vault/) for details.
### Configuration
In the **App Registrations** pane of the Azure Portal, follow these steps:
1. Create a new app registration.
2. Copy the **Application (Client) ID** for later use.
3. Go to **Manage** &gt; **Certificates & Secrets** &gt; **New client secret**, and add a new client secret. Make a note of the expiration you chose and create a new secret before that.
4. Copy the **Value** of the secret for later use.
In the Azure Key Vault, follow these steps:
#### Using Azure Key Vault (read-only)
When using Azure Key Vault (read-only) plugin, the Vault admin is responsible for correctly provisioning the secrets that Orchestrator will use. The format in which these secrets must be provisioned differs between secret types (asset versus robot password) and between secret engines.
For instructions on how to provision the secrets, see the following:
* [Storing unattended robot credentials in Azure Key Vault (read-only)](storing-unattended-robot-passwords-in-azure-key-vault-read-only.md)
* [Storing assets in Azure Key Vault (read-only)](storing-assets-in-azure-key-vault-read-only.md)
## HashiCorp Vault integration
HashiCorp Vault is a plugin you can use as a credential store with Orchestrator.
* **HashiCorp Vault** – a read-write plugin (secrets are created through Orchestrator)
* **HashiCorp Vault (read-only)** – a read-only plugin (you must provision the secrets in the vault directly)
### Prerequisites
* A network that allows for interconnectivity between the Orchestrator service and the HashiCorp Vault server:
  * The API port used by HashiCorp Vault for API requests must be open through any firewall and reachable from the internet. That port is `8200` in a typical install.
  * If the customer's firewall does not allow connectivity from any internet IP, Orchestrator's IP addresses must be whitelisted.
* You must configure one of the supported authentication methods:
  * **AppRole** (recommended)
  * **UsernamePassword**
  * **LDAP**
  * **Token**
    See how to [configure authentication](integrating-credential-stores.md).
* You must configure one of the supported secrets engines:
  * **KeyValueV1** - available for both HashiCorp Vault and HashiCorp Vault (read-only) plugins
  * **KeyValueV2** - available for both HashiCorp Vault and HashiCorp Vault (read-only) plugins
  * **ActiveDirectory** - available only for HashiCorp Vault (read-only) plugin
* The chosen authentication method must have a policy that allows the following capabilities on the path where you plan to store your secrets:
  * For HashiCorp Vault (read-only) plugin: `read`
  * For HashiCorp Vault plugin: `create`, `read`, `update`, `delete`, and optionally `delete` on the metadata path, if using the `KeyValueV2` secrets engine.
The following is an example of how to configure a development version of HashiCorp Vault, running in a docker container, to be used as a credential store with Orchestrator. The examples should be adapted to your own environment. Please consult the [official documentation](https://www.vaultproject.io/docs) of HashiCorp Vault for details.
#### Configuring authentication
To start creating and reading secrets, you first need to configure the authentication method by taking the following steps:
1. Open a shell inside the container:
   docker exec -it dev-vault sh
2. Log in as root. Make sure you have the root token displayed in the logs to set an environment variable with it by running the following command:
   export VAULT_TOKEN=s.hA7RJ5lBqSnKUPd8nrQBaK1f
3. Check the Vault status by running the following command:
   vault status
4. Add a dummy secret for Orchestrator in the KV store:
5. Give Orchestrator access to the newly created `secret/applications/orchestrator` path. For this, you must first create a [policy](https://www.vaultproject.io/docs/concepts/policies) for reading and writing to this path and all its subpaths by running the following command:
   cat <<EOF | vault policy write orchestrator-policy -
   path "secret/data/applications/orchestrator/*" {
     capabilities = ["create", "read", "update", "delete"]
   path "secret/metadata/applications/orchestrator/*" {
     capabilities = ["delete"]
   EOF
   :::note
   When using a KeyValueV2 secrets engine , secrets are written and fetched at path `<mount>/data/<secret-path>`, as opposed to `<mount>/<secret-path>` in KeyValueV1. It does not change any of the CLI commands (i.e., you do not specify data in your path).
   However, it does change the policies, since capabilities are applied to the real path. In the previous example, the path is `secret/data/applications/orchestrator/*` since we are working with a KeyValueV2 secrets engine. If a KeyValueV1 were used, the path would have been `secret/applications/orchestrator/*`.
   The capability to delete on the metadata path is needed only if you want to ensure Orchestrator does not leave behind test keys when verifying connectivity. If this capability is not granted, then a key will be created and left behind when creating the Credential Store in Orchestrator.
6. Enable authentication using the `userpass` [authentication method](https://www.vaultproject.io/docs/auth), then create a user for Orchestrator and assign the previously created policy:
   vault auth enable userpass
   vault write auth/userpass/users/orchestrator password=123456 policies=orchestrator-policy
   :::note
   Orchestrator supports multiple authentication modes. See the [HashiCorp Vault documentation](https://www.vaultproject.io/docs/auth/userpass) for how to configure them.
7. Check that you have configured everything correctly by logging in and trying to read the secret you created earlier:
   vault login -method=userpass username=orchestrator password=123456
   Output of this command:
   WARNING! The VAULT_TOKEN environment variable is set! This takes precedence
   over the value set by this command. To use the value set by this command,
   unset the VAULT_TOKEN environment variable or set it to the token displayed
   below.
   Success! You are now authenticated. The token information displayed below
   is already stored in the token helper. You do NOT need to run "vault login"
   again. Future Vault requests will automatically use this token.
   Key                    Value
   token                  s.nwombWQH3gGPDhJumRzxKqgI
   token_accessor         aGJL6Pzc6fRRuP8d8tTjS2Kj
   token_duration         768h
   token_renewable        true
   token_policies         ["default" "orchestrator-policy"]
   identity_policies      []
   token_meta_username    orchestratorWARNING! The VAULT_TOKEN environment variable is set! This takes precedence
   below.
   Key                    Value
   token_duration         768h
8. Take this token and set it instead of the root token, then try to read the test secret:
   export VAULT_TOKEN=s.nwombWQH3gGPDhJumRzxKqgI
   vault kv get secret/applications/orchestrator/testSecret
====== Metadata ======
Key              Value
created_time     2020-10-12T06:24:41.7827631Z
deletion_time    n/a
destroyed        false
version          1
=========== Data ===========
Key                    Value
supersecretpassword    123456====== Metadata ======
Key              Value
deletion_time    n/a
destroyed        false
version          1
Key                    Value
:::note
You can also enable [appRole](https://www.vaultproject.io/docs/auth/approle) Orchestrator by running the following command:
/ # vault auth enable approle
/ # vault write auth/approle/role/orchestrator policies=orchestrator-policy
/ # vault read auth/approle/role/orchestrator/role-id
/ # vault write -f auth/approle/role/orchestrator/secret-id
You will now have a role-id and secret-id for configuring in Orchestrator.
#### Configuring the Active Directory Secrets Engine
To configure the Active Directory secrets engine, take the following steps:
1. Enable the Active Directory secrets engine by running the following command:
   vault secrets enable ad
2. Configure the credentials that HashiCorp Vault uses to communicate with Active Directory to generate passwords:
   vault write ad/config \
       binddn=$USERNAME \
       bindpass=$PASSWORD \
       url=ldaps://138.91.247.105 \
       userdn='dc=example,dc=com'
3. Configure a role that maps a name in HashiCorp Vault to an account in Active Directory. When applications request passwords, password rotation settings will be managed by this role.
   vault write ad/roles/orchestrator service_account_name="my-application@example.com"
4. Grant `orchestrator` access to its credentials at `ad/creds/orchestrator` using an authentication method, such as AppRole.
   path "ad/creds/orchestrator" {
     capabilities = ["read"]
   EOF
#### Using HashiCorp Vault (read-only)
When using HashiCorp Vault (read-only) plugin, the Vault admin is responsible for correctly provisioning the secrets that Orchestrator will use. The format in which these secrets must be provisioned differs between secret types (asset versus robot password) and between secret engines.
[Storing unattended robot credentials in HashiCorp Vault (read-only)](storing-unattended-robot-credentials-in-hashicorp-vault-read-only.md)
[Storing assets in HashiCorp Vault (read-only)](storing-assets-in-hashicorp-vault-read-only.md)
## BeyondTrust integration
The BeyondTrust integration is read-only and comes in the form of two plugins you can choose from: **BeyondTrust Password Safe - Managed Accounts** and **BeyondTrust Password Safe - Team Passwords**.
While **BeyondTrust Password Safe - Managed Accounts** addresses the needs of organizations with either local or Active Directory accounts, **BeyondTrust Password Safe - Team Passwords** is suitable in scenarios where the credentials of small groups must be stored in an isolated environment.
The configuration of the two plugins is mostly identical, but there are some slight differences as well. This page covers both plugins.
### Prerequisites
* A BeyondTrust Server Cloud instance or a similar on-premises installation
* Beyond Insight credentials
1. Log in to the BeyondTrust Server Cloud instance or a similar on-premises installation using your Beyond Insight credentials.
2. Create an **API Registration** for UiPath Group of Service Accounts.
   Figure 7. Creating an API Registration
   ![Screenshot of the BeyondTrust configuration page](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-225698-11a95df2.webp)
3. Create an **Authentication Rule** to allow incoming API connections from UiPath.
   Figure 8. Creating an Authentication Rule
   ![Screenshot of the BeyondTrust configuration page](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-226204-05c52dcd.webp)
4. Create a new Group for UiPath Service Account(s) and add the following features:
   * **Password Safe Account**
   * **Password Safe Role**
     Figure 9. Creating a new Group
     ![Screenshot of the BeyondTrust Group Details page](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-231206-e5a8e1a3.webp)
5. You also need to assign **Smart Rules**:
   * Managed Accounts/Read-Only/Requester are sufficient for regular User Requests
   * For ISA access, Assets/ISA role is needed.
     Figure 10. Assigning Smart Rules
     ![Screenshot of the BeyondTrust Group Permissions page](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-229773-2e260841.webp)
6. Add the **API Registration** to the Group.
   Figure 11. Adding the API Registration to the Group
   ![Screenshot of the BeyondTrust Group Details page](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-231088-4e74ef31.webp)
7. Create a new **User** and assign the UiPath Group.
   Figure 12. Creating a new user
   ![Screenshot of the BeyondTrust Groups page](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-225937-32b2fb38.webp)
8. The following steps vary based on whether you are using **BeyondTrust Password Safe - Managed Accounts** or **BeyondTrust Password Safe - Team Passwords**.
If you are using **BeyondTrust Password Safe - Managed Accounts**, continue with the following steps:
1. Add your Managed Accounts under **Managed Systems**.
   Figure 13. Managed Systems page
   ![Screenshot of the BeyondTrust Managed Systems page](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-227527-dff6eba4.webp)
2. Make sure to use **API Enabled** for your Managed Accounts.
Figure 14. Managed Accounts page
![Screenshot of the BeyondTrust Managed Accounts page](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-226507-f3c0744c.webp)
If you are using **BeyondTrust Password Safe - Team Passwords**, continue with the following steps:
1. Go to the **Team Passwords** page.
   Figure 15. Team Passwords page
   ![Screenshot of the BeyondTrust Credentials page](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-232133-38c59648.webp)
2. Optionally create a new **Folder**.
3. Select a **Folder**.
4. Use the **Create New Credential** option.
## Thycotic Secret Server integration
:::note
Thycotic has been [rebranded as Delinea](https://delinea.com/news/thycoticcentrify-is-now-delinea) as a result of a merger. Please keep this in mind when configuring your credential store integrations.
### Prerequisites
* A Thycotic Secret Server cloud instance or on-premises installation.
:::important
Make sure to read through the [Delinea documentation](https://docs.delinea.com/online-help/integrations/uipath/setup/index.htm) for up-to-date information.
1. Log in to your Secret Server account.
2. Go to **Admin** &gt; **User Management** and click **Create User**. Select the **Application Account** checkbox to generate an application account.
3. Navigate to **Admin** &gt; **See All** &gt; **Tools and Integrations** &gt; **SDK Client Management** and set up a new onboarding rule in **Client Onboarding**. Note the onboarding rule name and key.
4. Edit the onboarding rule and assign the application account created at step 2.
5. Ensure the application account linked to the onboarding rule has permissions to the secrets accessed by Orchestrator. You can assign the application account to a group and grant that group access to the required folders, or grant it explicit access to the secrets.
## AWS Secrets Manager integration
### About AWS Secrets Manager
[AWS Secrets Manager](https://docs.aws.amazon.com/secretsmanager/latest/userguide/intro.html) is a tool that can be used as a credential store in Orchestrator.
It features two plugins:
* AWS Secrets Manager
* AWS Secrets Manager (read only)
The plugin you can use, namely read-only or read-write, is dictated by your AWS Identity and Access Management (IAM) policy permissions.
If you choose to use the read-only plugin, you must link an asset to a set of credentials that is already available in the AWS Secrets Manager.
### Prerequisites
To use this service:
* You need to have an AWS subscription.
* You need to create an IAM policy specific to the Secrets Manager, which you assign to the account's IAM role or user.
### Configuration
To integrate AWS Secrets Manager with Orchestrator, you need the access key and the secret key that are generated once you create an AWS IAM account.
* The **Access key ID** can be found on the **Security credentials** tab of your AWS IAM account.
* The **Secret key ID** is only provided after you create the account. It is therefore important to copy it for future use.
  If you misplace of forget your secret key ID, you need to create another access key, then replace the necessary information in Orchestrator.
In addition to that, you need to check the region you set in your AWS account, as this is what you will enter in the **Region** field while configuring the new credential store.
### Using AWS Secrets Manager (read only)
When using the AWS Secrets Manager (read only) plugin, the administrator is responsible for correctly provisioning the secrets that Orchestrator will use. The format in which these secrets must be provisioned differs between secret types (asset versus robot password) and between secret engines.
* [Storing unattended robot credentials in AWS Secrets Manager (read only)](storing-unattended-robot-credentials-in-aws-secrets-manager-read-only.md)
* [Storing assets in AWS Secrets Manager (read only)](storing-assets-in-aws-secrets-manager-read-only.md)
