# Users requests
> :::note
* GET requests to the `/odata/Users` or `/odata/Users({})` endpoints return an empty Domain for AD users.
* The `GetOrganizationUnits(Id)` and `GetRoles(Id)` requests only return folders and roles explicitly set for an auto-provisioned user. The ones inherited from the group configuration can be retrieved through the `/api/DirectoryService/GetDirectoryPermissions?userId={userId}` endpoint.
:::note
## Deleting a user
DELETE
`https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/Users(446)`
### Request headers
| Key | Value |
| Authorization | Bearer |
### Response code
204 No content
## Changing the language
The following example enables you to change the language for the user with the 749 Id to Japanese.
POST
`https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/Users(749)/UiPath.Server.Configuration.OData.ChangeUserCulture`
### Request headers
| Key | Value |
### Request body
    "culture": "ja"
### Response code
200 OK
## Provisioning a robot for a user
PUT
`https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/Users(13)`
### Request headers
| Key | Value |
### Request body
  "RobotProvision": {
     "UserName": "uipath\\john.smith",
     "RobotId": 53,
     "RobotType": "Development",
     "ExecutionSettings": {}
### Response code
200 OK
## Assigning roles
You can use this endpoint to assign one or more roles to the specified user ID, which can be the ID of a group, a user account, or a robot account.
POST
`https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/Users(9)/UiPath.Server.Configuration.OData.AssignRoles`
### Request headers
| Key | Value |
### Request body
  "roleIds": [
    1,3
**Example**
The below request updates the account or group with the user ID `9` by **overwriting** its assigned roles with the roles that have IDs `1` and `3`.
| Roles before request | Roles after request | Changes |
| No roles | `1` and `3` | Roles with IDs `1` and `3` have been assigned. |
| Roles with IDs `1` and `2` | `1` and `3` | Role with ID `2` was removed and role with ID `3` was assigned. |
| Role with ID `2` | `1` and `3` | Role with ID `2` was removed, and roles with IDs `1` and `3` were assigned. |
**cURL**
`curl -X POST "https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/Users({key})/UiPath.Server.Configuration.OData.AssignRoles" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"roleIds\": [ {RoleID1},{RoleID2} ] }"`
**Swagger UI** (available at `https://https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/swagger`)
Figure 1. Assigning roles
![Screenshot of the assigning roles API in Swagger](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-219761-ef799d28.webp)
### Step by step
Here's an example procedure for how to assign roles to an account:
1. Make a GET request at `/odata/Roles` to retrieve the list of roles.
   You can use any type of filter that OData supports, if needed.
2. Note the IDs for the roles you want to assign.
3. Make a GET request at `/odata/Users` to retrieve the list of accounts.
   The list includes groups, user accounts, and robot accounts.
4. Note the IDs for the accounts to which you want to assign roles.
5. Make a POST request to `/odata/Users({key})/UiPath.Server.Configuration.OData.AssignRoles` for each account to which you want to assign roles.
   * `{key}` is a single account ID for the account to which you want to assign roles
   * `{roleID}` is a single role ID for the role you want to assign; you can list multiple IDs, separated by a comma.
