# Settings requests
> Reference for settings API endpoints used to retrieve and manage Orchestrator service and robot settings
## Retrieving service settings used by the robot
The following request enables you to display all the service settings used by the Robot.
:::note
Please note that you need to include the Robot license key when making this request, as a header. The header's name must be X-ROBOT-LICENSE, as you can see in the example below.
GET
`https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/Settings/UiPath.Server.Configuration.OData.GetServicesSettings()`
### Request headers
| Key | Value |
| Authorization | Bearer |
### Response code
200 OK
### Response body
    "@odata.context": "https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/$metadata#System.Collections.Generic.Dictionary_2OfString_String",
    "Keys": [
        "ConfigurationUrl",
        "DeploymentUrl",
        "MonitoringUrl",
        "NotificationHubUrl",
        "LoggingUrl",
        "QueuesSvcUrl",
        "NuGet.Packages.ApiKey",
        "NuGetServiceApiKey",
        "ActivitiesFeed"
    "Values": [
        "https://your-domain-server.com",
        "https://your-domain-server.com/nuget/feed/documentation",
        "https://your-domain-server.com/signalr/hubs",
        "ec5b1111-5eb9-4264-a545-d5ed85c6301a",
        "https://your-domain-server.com/nuget/activities"
## Retrieving the robot execution settings
The example below enables you to retrieve the Robot runtime settings.
**GET**
`https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/Settings/UiPath.Server.Configuration.OData.GetExecutionSettingsConfiguration(scope=1)`
### Request headers
| Key | Value |
### Response code
200 OK
### Response body
  "@odata.context": "https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/$metadata#UiPath.Core.Settings.ExecutionSettingsConfiguration",
  "Scope": "Global",
  "Configuration": [
      "Key": "TracingLevel",
      "DisplayName": "Logging Level",
      "ValueType": "MultipleChoice",
      "DefaultValue": "Information",
      "PossibleValues": [
        "Verbose",
        "Trace",
        "Information",
        "Warning",
        "Error",
        "Critical",
        "Off"
      "Key": "LoginToConsole",
      "DisplayName": "Login To Console",
      "ValueType": "Boolean",
      "DefaultValue": "false",
      "PossibleValues": []
      "Key": "ResolutionWidth",
      "DisplayName": "Resolution Width",
      "ValueType": "Integer",
      "DefaultValue": "0",
      "Key": "ResolutionHeight",
      "DisplayName": "Resolution Height",
      "Key": "ResolutionDepth",
      "DisplayName": "Resolution Depth",
## Setting the number of hours an attended robot can run offline
The request below enables you to change the number of hours for which an Attended Robot retains its licenses in an offline environment to 24 hours.
Please note that this setting is applied when you first connect the Robot to Orchestrator, or after the UiPath Robot service is restarted. If you are running the Community version, you need to restart the tray for the change to take effect.
**POST**
`https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/Settings/UiPath.Server.Configuration.OData.UpdateBulk`
### Request headers
| Key | Value |
### Request body
    "settings": [{
        "Name@odata.type": "#String",
        "Name": "AttendedRobot.RunDisconnectedHours",
        "Value": "24"
### Response code
200 OK
