# Robot Statuses
> ![docs image](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-229678-0d62077e.webp)
## Licensing Statuses
**Only displayed for attended robots**. Displayed in front of the license type in the **Type** column. The following options are available:
* Green icon - licensed. Hovering over the icon displays the exact time and date the license was acquired.
* Red icon - unlicensed
If the UiPath Robot service is stopped, nothing is displayed.
## Connection Statuses
The connection status is the last known status of UiPath Robot as communicated through the most recent heartbeat. Hovering over this field displays the date and time of the last heartbeat. A robot is displayed as connected only if the UiPath Robot tray or Studio is open on the host machine.
**Only applicable to attended robots, or unattended robots used in attended mode.** Unattended runtimes and machines can be monitored at the folder level (**Monitoring** &gt; **Machines**). The connection status is displayed on the **Status** column. The corresponding icon is displayed in front of the username in the **User** column. The following options are available:
* ![docs image](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-latest_version.png-2224d1b4.webp) **Available** - UiPath Robot is not running a process and is free to be used.
* ![docs image](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-busy_robot.png-9ae1b250.webp) **Busy** - UiPath Robot is running a process. You **cannot** edit the username, machine and license type of a busy robot.
* ![docs image](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-package_not_available.png-a2fdc601.webp) **Unresponsive** - UiPath Robot and Orchestrator have not communicated in the last two minutes.
* ![docs image](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-stopped_job.png-5b46ad5d.webp) **Disconnected** - the UiPath Robot service is not running.
  :::note
  Robot start commands are received through SignalR or requested on a heartbeat. The username and password UiPath Robot uses for authentication purposes are transmitted only on heartbeats, thus enabling it to log in and execute an indicated process.
