# Logging Levels
> | Logging Level | Default Logs | User-Defined Logs |
| **Off** | None | None |
| **Critical** | All messages logged with Critical level or higher. | All messages logged with Critical level or higher. |
| **Error** | All messages logged with Error level or higher. | All messages logged with Error level or higher. |
| **Warning** | All messages logged with Warning or higher. | All messages logged with Warning or higher. |
| **Information** | All messages logged with Information or higher. | All messages logged with Information or higher. |
| **Trace** | All messages logged with Trace level or higher. | All messages logged with Trace level or higher. |
| **Verbose** | All messages logged with Trace level and Workflow Tracking logs. | All messages logged with Trace level. |
## Logging Levels in UiPath
The **Verbose** level logs a message for both the activity **start** and **end**, plus the values of the variables and arguments that are used.
By default, the Verbose level includes:
* **Execution Started** log entry - generated every time a process is started.
* **Execution Ended** log entry - generated every time a process is finalized.
* **Transaction Started** log entry - generated every time a transaction item is obtained by the robot from Orchestrator.
* **Transaction Ended** log entry - generated every time the robot sets the transaction status to either Success or Failed.
* **Activity Information** log entry - generated every time an activity is **started**,**faulted** or **finished** inside a workflow.
  :::note
  The priority order of the log types is: **Verbose** &lt; **Trace** &lt; **Information** &lt; **Warning** &lt; **Error** &lt; **Critical** &lt; **Off**.
  <colgroup>
  <col/>
  <col/>
  <col/>
  <col/>
  <col/>
  <col/>
  </colgroup>
  Log Level
  Logged
  Example / Comment
  Log File
  Output Panel
  Orchestrator Log page
  Verbose
  Activities
  <code>Trace {"message":{"DisplayName":"Message box","State":"Executing","Activity":"UiPath.Dialog.Activities.MessageBox","Arguments":{"Caption":"","Text":"String
                                            in message BOX"}...Trace {"message":{"DisplayName":"Message box","State":"Closed","Activity":"UiPath.Dialog.Activities.MessageBox","Arguments":{"Caption":"","Text":"String
                                            in message BOX","ChosenButton":"Ok"}</code>
  Yes
  No
  Yes
  Verbose
  Variables
  <code>"Variables":{"NewTransaction":"False"}}</code>
  Yes
  No
  Yes
  Verbose
  Arguments (properties)
  <code>"Arguments":{"Caption":"","Text":"String in message BOX","ChosenButton":"Ok"}</code>
  Yes
  No
  Yes
  Trace
  Activities
  <code>Trace {"message":{"DisplayName":"Main","State":"Executing","Activity":"System.Activities.DynamicActivity"}Trace {"message":{"DisplayName":"Main","State":"Executing","Activity":"System.Activities.Statements.Flowchart"}</code>
  Yes
  No
  Yes
  Information
  WriteLine
  Log Message
  <code>Info {"message":"message from activity"</code>
  Note: Except messages logged with Trace level set in activity.
  Yes
  Yes
  Yes
  Warning
  Warnings
  <code>Warn {"message":"Warning from log message activity"</code>
  Yes
  Yes
  Yes
  Warning
  Errors
  <code>Error {"message":"Error from log message activity"</code>
  Yes
  Yes
  Yes
  Warning
  Critical
  Critical Errors
  Yes
  Yes
  Yes
  Error
  Errors
  Yes
  Yes
  Yes
  Error
  Critical
  Fatal
  Critical Errors
  Yes
  Yes
  Yes
  Critical
  Critical
  Fatal
  Critical Errors
  Yes
  Yes
  Yes
  OFF
  n/a
  n/a
  No
  No
  No
## Log Message Types
There are several possible occurrences of log messages, depending on the event that is logged, as follows:
### Default Logs
Generated by default when the execution of a project starts and ends, when a system error occurs and the execution stops, or when the logging settings are configured to log the execution of every activity.
:::note
These logs have the `Default` value in the `logType` field.
The events logged by this category are:
* **Execution Start** is generated every time a process is started. This is logged starting with the **Information** logging level.
* **Execution End** is generated every time a process is finalized. This is logged starting with the **Information** logging level.
* **Transaction Start** is generated every time a transaction within a process is started. This is logged starting with the **Information** logging level.
* **Transaction End** is generated every time a transaction within a process is finalized. This is logged starting with the **Information** logging level.
* **Error Log** is generated every time the execution encounters an error and stops. This is logged starting with the **Error** logging level.
* **Debugging Log** is generated if the Robot Logging Setting is set to Verbose and contains, activity names, types, variable values, arguments etc. This is logged starting with the **Trace** logging level.
### User-Defined Logs
Generated according to the process designed by the user in Studio, when using the **Log Message** activity or the **Write Line** activity.
:::note
These logs have the `User` value in the `logType` field.
## Log Fields
There are multiple types of log fields that can be found throughout the above log message types. These can be classified as follows:
### Default Fields
These log fields are present in all execution type logs, such as SQL (if configured), Elasticsearch (if configured), and the default EventViewer Logs:
* `Message` - The log message.
* `Level` - Defines the log severity.
* `Timestamp` - The exact date and time the action was performed.
* `FileName` - The name of the `.xaml` file being executed.
* `jobId` - The key of the job running the process.
* `processName` - The name of the process that triggered the logging.
* `processVersion` - The version number of the process.
* `windowsIdentity` - The name of the user that performed the action that was logged.
* `robotName` - The name of the robot (as defined in Orchestrator).
In an environment with multiple Robots on a machine which are connected to Orchestrator, the Event Viewer logs might display the following message: “Current user did not login to the application!". This occurs only if you remove a Robot that still had logs to send to Orchestrator.
:::note
The `processName` and `processVersion` fields do not appear in logs if the process is run locally, without being connected to Orchestrator.
### Type-specific Fields
These logs are present depending on the log type:
#### Execution End
* `totalExecutionTimeInSeconds`
* `totalExecutionTime`
#### Transaction Start
* `queueName`
* `transactionID`
* `transactionState`
#### Transaction End
* `queueName`
* `transactionID`
* `transactionStatus`
* `transactionExecutionTime`
* `processingExceptionType`
* `processingExceptionReason`
* `queueItemReviewStatus`
* `queueItemPriority`
#### Debugging Log
* `activityInfo`, which is a JSON message with the following fields:
  * `DisplayName`
  * `State` (Faulted, Closed, Executing)
  * `Activity`
  * `Variables`
  * `Arguments`
    :::note
    Only `totalExecutionTimeInSeconds`, `totalExecutionTime` and `queueName` are always present in the log messages. `Variables` and `Arguments` usually have sub-fields.
### User-defined Fields
These fields are defined in Studio by using the **Add Log Fields** activity and appear in all subsequent logs after the activity is generated, unless they are removed by the **Remove Log Fields** activity.
:::note
Creating custom log fields that have the same name as a default log field causes the logging process to become corrupted and may cause issues in the workflow you are running.
For example, creating a custom log field called `jobId` causes this issue, as `jobId` is a log field that is generated by default.
