# About Libraries
> A library describes a system of activities with a well-contoured business function, making them suitable for sharing and reusability.
Orchestrator allows you to manage libraries centrally from the **Libraries** page (Tenant &gt; **Packages** &gt; **Libraries** tab). Depending on your setup, libraries here are shared across tenants and can be used by any user with the right permissions.
From the **Libraries** page, you can view and delete all the libraries that had been published from UiPath Studio, as well as those that were [uploaded manually](managing-libraries.md). There you can see the version of each package and release notes for each version if any (should be added in Studio to better keep track of changes between versions).
## Library Feeds
Feeds are package streams that allow you to store and group packages in order to control their availability and isolation.
:::note
Using v3 NuGet feed URLs results in a couple of display issues with packages.
* The publish date of a package is not correct.
* For MyGet feeds, the total number of packages is much greater than the actual number of packages uploaded to the feed.
### Tenant feed
Libraries are isolated at the tenant level, meaning that the data is separated across tenants. Libraries either published from Studio or manually uploaded by the user are stored within the chosen feed.
Feed settings and security can be configured from the tenant settings &gt; **Deployment** tab, either at the tenant level or from the Orchestrator host portal. Settings here only affect tenant feeds; folder feeds and personal workspace feeds are always internal and available in the context of the respective folder or personal workspace alone.
### Host feed
The host feed contains all official UiPath libraries which are available across tenants. You can upload libraries to this feed.
### Custom feed
A custom NuGet feed or a local folder.
The host feed contains all official UiPath libraries which are available across tenants. You can also publish your own libraries to this feed to share them between tenants.
Allowing libraries upload into the host feed is done from the tenant **Settings** page. See [libraries deployment settings](deployment-tab.md#libraries) for details on how to choose and configure feeds. Tenants use the **host feed** by default, so if you haven't configured anything explicitly, the host feed is used.
## Libraries Permissions
To be able to perform various operations on the **Libraries** page, you need to be granted the corresponding permissions on Libraries:
* **View** - Downloading a library and viewing any libraries-related details;
* **Create** - Uploading a library.
