# Assets Requests
> :::note
Global and Per Robot text assets support up to 1,000,000 characters.
:::note
:::important
`$filter` queries return the result of a custom filter that uses **Name** and **Description** parameters in a `contains` function.
## Retrieving a specific asset
The call below enables you to display all the available information for the asset with the `DocAPITest` name and `455` Id.
GET
`https://{yourDomain}/odata/Assets/UiPath.Server.Configuration.OData.GetRobotAsset(robotId='455',assetName='DocAPITest')`
### Request headers
| Key | Value |
| Authorization | Bearer |
### Response code
200 OK
### Response body
    "@odata.context": "https://{yourDomain}/odata/$metadata#UiPath.Application.Dto.Assets.RobotAssetDto",
    "Name": "DocAPITest",
    "ValueType": "Text",
    "StringValue": "An asset added through an API call",
    "BoolValue": false,
    "IntValue": 0,
    "CredentialUsername": "",
    "CredentialPassword": ""
## Retrieving per robot assets
To perform a GET request to the `/odata/Assets/UiPath.Server.Configuration.OData.GetRobotAssetByRobotId()` endpoint, you need to provide the `robotId` and `assetName` in the URL. Please note that only the username is returned for Per Robot credential assets, as you can see in the example below.
GET
`https://{yourDomain}/odata/Assets/UiPath.Server.Configuration.OData.GetRobotAssetByRobotId(robotId=193,assetName='Testing')`
### Request headers
| Key | Value |
### Response code
200 OK
### Response body
  "Name": "Testing",
  "ValueType": "Credential",
  "StringValue": "",
  "BoolValue": false,
  "IntValue": 0,
  "CredentialUsername": "DocBot",
## Adding an asset
The following example enables you to create a new global asset, of type text.
POST
`https://{yourDomain}/odata/Assets`
### Request headers
| Key | Value |
### Request body
    "ValueScope": "Global",
### Response code
200 OK
### Response body
    "@odata.context": "https://{yourDomain}/odata/$metadata#Assets/$entity",
    "CanBeDeleted": true,
    "Value": "An asset added through an API call",
    "BoolValue": false,
    "IntValue": 0,
    "CredentialPassword": "",
    "Id": 455,
    "KeyValueList": []
