# SmartCard Authentication
> :::important
This feature only works if [Login to Console](robot-settings.md) is set to **True**.
:::important
SmartCard (Common Access Cards or Personal Identity Verification Cards) authentication is a secure way to authenticate unattended Robots, in addition to basic authentication credentials. A SmartCard has a unique PIN. Multiple users can be registered to a card, in which case all users have the same PIN. A user can also be registered to multiple cards, in which case multiple PINs are used for the same user.
:::note
UiPath® does not support simultaneous process execution on Robots registered with the same username but different authentication methods.
Both virtual and physical cards can be used for authentication, as long as they are part of a single Active Directory domain. The corresponding user must belong to the same domain. Virtual card authentication is only possible on Windows 8.1 and above.
:::note
The SmartCard needs to be inserted with every authentication. As long as the SmartCard is inserted, the associated Robot is available on the corresponding machine.
It is highly recommended to consult your company’s password policy before using the SmartCard authentication method. Credentials for a Robot that authenticates with a SmartCard may be stored in either the SQL Server or CyberArk. Find out more about storing Robot credentials in CyberArk [here](storing-credentials-in-cyberark.md).
## Enabling Smart Card Authentication
To enable SmartCard authentication, select **Smart Card** when configuring the credential type at the user level. This option is only available if the [Features.SmartCardAuthentication.Enabled](https://docs.uipath.com/orchestrator/standalone/2021.10/installation-guide/uipath-orchestrator-dll-config#featuressmartcardauthenticationenabled) parameter is set to **True**.
<iframe width="100%" height="100%" src="https://documentationpicturerepo.blob.core.windows.net/videos/2020.10_Orchestrator/smart_card.mp4" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
