# General Tab
> | Field | Description |
| **Application Settings** | **Time Zone** - The time zone of the tenant. By default, this field is set to UTC.<br /><br />The timezone list depends on the machine. To ensure that all the instances under a multi-node Orchestrator installation have the same timezone list, they must use the same operating system version.<br /><br />It is recommended that the tenant and the Robots have the same time zone.<br /><br />**Language** - The language of the Orchestrator user interface for the current tenant, including email notifications and alerts. This setting does not affect robot logs or event logs, which use your Windows language.<br /><br />A logo can be added at the `host` and/or `tenant` levels. The host setting will be overridden by any logo added at the tenant level.<br /><br />In Automation Suite, changing the company logo is performed from the **Organization Settings** page. Learn more about [managing organization settings in Automation Suite](https://docs.uipath.com/automation-suite/docs/managing-your-organization). |
| **Client Binaries (Robot, Studio, Assistant) Auto-Update Settings** | **Auto-fill available product versions** (host setting) - Configures the update policies to contain the latest versions of client binaries. If you need to manage update versions manually, disable this option and follow the steps described in [this article](auto-updating-client-components.md).<br /><br />**Ignore auto-update status for robot machines that were offline for more than ___ days** (tenant setting) - This excludes inactive machines from the update process and no longer takes them into account when the update status is reported. |
| **Personal Workspaces** (tenant setting) | Enable the [Personal Workspaces](personal-workspaces.md) feature.<br /><br />This action cannot be reversed, once the Personal Workspaces feature is enabled it cannot be disabled.<br /><br />**Enable Personal Workspace** - Create personal workspaces for all users in a tenant that use a certain attended licensing profile, while also selecting the [UI profile](personal-workspaces.md) to be used for those users. |
| **Standard Roles** (tenant setting) | Create standard roles for modern folders. These roles empower you to leverage the benefits of user groups.<br /><br />Click **Create Role** next to each of the roles you want to be automatically created. |
| **Modern Folders** | Enable the [Account-Machine Mappings feature](about-machines.md). |
| **Classic Folders** | **Activate Classic Folders** - Enable classic folders.<br /><br />Use this setting with caution, since classic folders are disabled and will soon be [deprecated](https://docs.uipath.com/overview/other/latest/overview/deprecation-timeline). |
| **Email Setup** | Enable alerts email.<br /><br />For more information, see [Setting Up Email Alerts](setting-up-alert-emails.md). |
| **Application Settings** | **Time Zone** - The time zone of the tenant. By default, this field is set to UTC.The timezone list depends on the machine. To ensure that all the instances under a multi-node Orchestrator installation have the same timezone list, they must use the same operating system version.It is recommended that the tenant and the Robots have the same time zone.**Language** - The language of the Orchestrator user interface for the current tenant, including email notifications and alerts. This setting does not affect robot logs or event logs, which use your Windows language.A logo can be added at the `host` and/or `tenant` levels. The host setting will be overridden by any logo added at the tenant level.In Automation Suite, changing the company logo is performed from the **Organization Settings** page. Learn more about [managing organization settings in Automation Suite](https://docs.uipath.com/automation-suite/docs/managing-your-organization). |
| **Client Binaries (Robot, Studio, Assistant) Auto-Update Settings** | **Auto-fill available product versions** (host setting) - Configures the update policies to contain the latest versions of client binaries. If you need to manage update versions manually, disable this option and follow the steps described in [this article](auto-updating-client-components.md).**Ignore auto-update status for robot machines that were offline for more than ___ days** (tenant setting) - This excludes inactive machines from the update process and no longer takes them into account when the update status is reported. |
| **Personal Workspaces** (tenant setting) | Enable the [Personal Workspaces](personal-workspaces.md) feature.This action cannot be reversed, once the Personal Workspaces feature is enabled it cannot be disabled.**Enable Personal Workspace** - Create personal workspaces for all users in a tenant that use a certain attended licensing profile, while also selecting the [UI profile](personal-workspaces.md) to be used for those users. |
| **Standard Roles** (tenant setting) | Create standard roles for modern folders. These roles empower you to leverage the benefits of user groups.Click **Create Role** next to each of the roles you want to be automatically created. |
| **Classic Folders** | **Activate Classic Folders** - Enable classic folders.Use this setting with caution, since classic folders are disabled and will soon be [deprecated](https://docs.uipath.com/overview/other/latest/overview/deprecation-timeline). |
| **Email Setup** | Enable alerts email.For more information, see [Setting Up Email Alerts](setting-up-alert-emails.md). |
