# Managing Webhooks
> Create and configure webhooks in Orchestrator to send event notifications to external systems.
## Creating a Webhook
To create a webhook, choose one of the following options:
* From the Orchestrator toolbar, select the plus icon, then select **Webhook**.
* From the tenant page, select **Webhooks**, then select **Add webhook**.
Next, on the **Add Webhook** page, continue with the following configuration:
1. In the mandatory **Name** field, enter a name for your webhook. A string of maximum 128 characters is allowed.
   :::note
   Make sure the **Name** is unique, as two live webhooks cannot share the same name at tenant level. A specific name is released when the corresponding webhook is deleted.
2. In the **Description** field, enter a description for your webhook. A string of maximum 256 characters is allowed.
3. In the **URL** field provide a custom URL to which you want to send information from Orchestrator.
4. Select the **Disable SSL Verification** check box if you do not want the webhook communication to be secure. **This option is not recommended!**
5. Clear the **Enabled** check box if you want to disable the webhook you are creating.
6. (Optional) Add a custom secret, up to 100 characters long, if you want the webhook authentication to be more secure.
7. Select the **Send All Events** or **Select Individual Events** option. The first enables you to send all the available Orchestrator events to the specified URL, while the latter enables you to indicate individual events.
8. Select **Save**. The webhook has been created. You start receiving the corresponding payloads as soon as they are triggered.
## Editing a Webhook
1. Select the corresponding **Edit** button. The **Edit** page is displayed.
2. Make the necessary changes to your webhook (all fields are editable).
3. Select **Update**. Your changes are saved successfully and the updated **Webhooks** page is displayed.
## Enabling or Disabling a Webhook
To enable or disable a webhook, click the toggle in the **Enabled** column. When a webhook is enabled, the toggle is blue.
## Removing a Webhook
1. Select the corresponding **Delete** button. You are prompted to confirm.
2. Select **Yes**. The webhook is removed and the updated **Webhooks** page is displayed.
