# Default roles
> Permissions included in each default Orchestrator role and how to view or edit role configurations.
This page displays the permissions included for each default role in Orchestrator.
You can view and edit the permissions for each role from the **Roles** page by clicking the ![](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-more-options-icon-More_VT-960a3e20.png) **More Actions** icon on the right end of a row.
If a role cannot be edited, you have the option to duplicate and customize it as a new role instead (not available for mixed roles).
## Administrator role
A role that has all tenant- and folder-level permissions.
This is a **mixed role** and includes both tenant and folder permissions and is no longer available for new tenants. To replicate its permissions, use the following role combination:
* **Orchestrator Administrator** at the tenant level.
* **Folder Administrator** at the folder level.
With mixed roles, for a global operation, only the user's tenant permissions are taken into consideration; for a folder-specific operation, if a custom role is defined, folder permissions are applied in favor of any tenant permissions present.
It includes the following permissions, which cannot be changed.
### Tenant Permissions
Figure 1. Tenant permissions ![Tenant permissions](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-tenant-permissions-260866-028af467.webp)
### Folder Permissions
Figure 2. Folder permissions ![Folder permissions](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-folder-permissions-260897-fb8c3359.webp)
## Robot role
:::important
This is a deprecated mixed role and is no longer available for new tenants. To replicate its permissions, use the following role combination:
* **Allow to be Automation User** at the tenant level
* **Automation User** at the folder level
The Robot role can still be used in any existing tenants. For more information on deprecated features and capabilities, check the [Deprecation timeline](https://docs.uipath.com/overview/other/latest/overview/deprecation-timeline#orchestrator) page.
All permissions required to execute processes.
This is a **mixed role** and includes both tenant and folder permissions. With mixed roles, for a global operation, only the user's tenant permissions are taken into consideration; for a folder-specific operation, if a custom role is defined, folder permissions are applied in favor of any tenant permissions present.
:::note
As robot accounts can write logs without the explicit assignment of the **Create** permission on **Logs**, Orchestrator skips the check on this permission.
By default, the role has the following permissions, which can be changed.
Figure 3. Tenant permissions ![Tenant permissions](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-tenant-permissions-260905-d8fecf0f.webp)
Figure 4. Folder permissions ![Folder permissions](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-folder-permissions-260913-ebc60972.webp)
## Personal Workspace Administrator Role
This is a **folder role** and it includes the following permissions by default, which cannot be edited.
Figure 5. Folder permissions for Personal Workspace Administrator role
![Folder permissions for Personal Workspace Administrator role](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-folder-permissions-for-personal-workspace-administrator-role-561653-cdc2b031.webp)
## Standard roles
The following roles are pre-configured with the permissions for the tenant level or the folder level that are required to work in folders.
These roles cannot be changed, but you can duplicate and customize them as a new role if needed.
Below you can see the permissions granted for each standard role.
### Orchestrator Administrator
This role is granted all tenant-level permissions, and should be assigned at the tenant level to any users in charge with the management of all tenant entities.
:::note
The Orchestrator Administrator role holds the same Orchestrator permissions as the [Tenant Administrator](https://docs.uipath.com/automation-suite/automation-suite/2.2510/admin-guide/managing-access#groups-and-roles) role.
We recommend this role over **Administrator**, which is not relevant in a modern folder infrastructure.
This is a **tenant role** and includes the following permissions by default, which cannot be changed.
Figure 6. Orchestrator Administrator permissions
![Orchestrator Administrator permissions](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-orchestrator-administrator-permissions-602052-572c20b5.webp)
### Allow to Be Folder Administrator
A role with the minimum tenant-level permissions needed to manage their own folders and subfolders.
Accounts that have the **Allow to be Folder Administrator** tenant role should also have the **Folder Administrator** folder role assigned to them at the folder level.
Figure 7. Allow to Be Folder Administrator permissions
![Allow to be Folder Administrator permissions](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-allow-to-be-folder-administrator-permissions-602061-2365bd57.webp)
### Folder Administrator
A user with the minimum folder-level permissions needed to manage their own folders and subfolders.
Accounts that have the **Folder Administrator** folder role should also have the **Allow to be Folder Administrator** tenant role assigned to them at the tenant level.
This is a **folder role** and includes the following permissions by default, which cannot be changed.
Figure 8. Folder Administrator permissions
![Folder Administrator permissions](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-folder-administrator-permissions-561657-2f4081ce.webp)
### Allow to be Automation User
A user with the minimum folder level permissions needed to execute processes from Assistant, as well as unattended automations.
Accounts that have the **Allow to be Automation User** tenant role should also have the **Automation User** folder role assigned to them at the folder level.
Figure 9. Allow to be Automation User permissions
![Allow to be Automation User permissions](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-allow-to-be-automation-user-permissions-299416-a33c6684.webp)
### Automation User
We recommend that accounts that have the **Automation User** folder role also have the **Allow to be Automation User** tenant role assigned to them at the tenant level.
Figure 10. Automation User permissions
![Automation User permissions](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-automation-user-permissions-561649-06f9fe78.webp)
### Allow to be Automation Publisher
A user who can publish processes to Orchestrator.
This role can be assigned on top of **Allow to be Automation User** to allow a user to both publish and execute a process.
Accounts that have the **Allow to be Automation Publisher** tenant role should also have the **Automation Publisher** folder role assigned to them at the folder level.
Figure 11. Allow to be Automation Publisher permissions
![Allow to be Automation Publisher permissions](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-allow-to-be-automation-publisher-permissions-299426-980a5566.webp)
### Automation Publisher
This role can be assigned on top of **Automation User** to allow a user to both publish and execute a process.
Accounts that have the **Automation Publisher** folder role should also have **Allow to be Automation Publisher** tenant role assigned to them at the tenant level.
Figure 12. Automation Publisher permissions
![Automation Publisher permissions](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-automation-publisher-permissions-299432-fac8ba6f.webp)
### Allow to be Automation Developer
A user who creates automation projects, but does not have direct access to complex and expensive resources, such as storage buckets.
Accounts that have the **Allow to be Automation Developer** tenant role should also have the **Automation Developer** folder role assigned to them at the folder level.
Figure 13. Allow to be Automation Developer permissions
![Allow to be Automation Developer permissions](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-allow-to-be-automation-developer-permissions-525056-04ca96a5.webp)
### Automation Developer
Accounts that have the **Automation Developer** folder role should also have the **Allow to be Automation Developer** tenant role assigned to them at the tenant level.
Figure 14. Automation Developer permissions
![Automation Developer permissions](https://dev-assets.cms.uipath.com/assets/images/orchestrator/orchestrator-automation-developer-permissions-561661-526438be.webp)
