# Task Catalogs requests
> API request examples for retrieving task catalogs accessible to users in classic folders.
## Retrieve Task catalogs in a folder
This request enables you to retrieve all the task catalogs in the classic folders that the user has access to.
GET
`https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/TaskCatalogs?$top=3`
### Request headers
| Key | Value |
| Authorization | Bearer |
### Response code
200 OK
### Response body
    "@odata.context": "https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/$metadata#TaskCatalogs",
    "@odata.count": 3,
    "value": [
            "Name": "Greatness",
            "Description": null,
            "LastModificationTime": "2019-10-30T16:45:57.533Z",
            "Id": 7
            "Name": "Orchestrator",
            "Description": "Mother",
            "LastModificationTime": "2019-10-30T16:57:44.1Z",
            "Id": 12
            "Name": "Credentials",
            "LastModificationTime": null,
            "Id": 20
## Retrieve Task Catalog details
This request enables you to retrieve task catalog details according to the `TaskCatalogId`. The `TaskCatalogId` must be included in the request.
GET
`https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/TaskCatalogs(7)`
### Request headers
| Key | Value |
### Response code
200 OK
### Response body
    "@odata.context": "https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/$metadata#TaskCatalogs/$entity",
    "Name": "Orchestrator Catalog",
    "Description": "da",
    "LastModificationTime": "2020-02-05T13:31:09.45Z",
    "Id": 7
## Update Task Catalog
This request enables you to modify task catalog details based on the `TaskCatalogId`. The `TaskCatalogId` must be included in the request.
GET
`https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/TaskCatalogs(7)/UiPath.Server.Configuration.OData.UpdateTaskCatalog`
### Request headers
| Key | Value |
### Request body
  "Name": "Expense reports",
  "Description": "Expense reports generation"
### Response code
200 OK
