industry-department-solutions
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
Uploading files via Python with signed URLs
Upload files to Peak via signed URLs using Python for programmatic file uploads in data pipelines or scheduled batch processes.
Use Python to programmatically upload files to Peak via signed URLs. This approach is ideal for automating file uploads in data pipelines or scheduled batch processes.
Prerequisites​
Before uploading files via Python, ensure you have the following:
  • You have Python 3.6 or later installed.
  • You have the requests library installed (pip install requests).
  • You have a tenant API key.
  • You have the file ready for upload on your local machine.
Steps​
Create a Python script to generate a signed URL and upload your file:
  1. Create a new Python script file (e.g., upload_to_peak.py).
  2. Import the required libraries:
     import os
    import requests
     import os
    import requests
  3. Define the API key and file name. Store the API key in an environment variable instead of hardcoding it:
     tenant_api_key = os.environ["peak_tenant_api_key"]
     file_name = "sample_20181112.csv"
  4. Generate a signed URL:
     url = "https://api.peak.ai/file/signedurl/client"
     headers = {
          "Content-Type": "application/json",
          "Authorization": tenant_api_key,
     payload = {"fileName": file_name}
     response = requests.post(url, json=payload, headers=headers)
     response.raise_for_status()
     signed_url = response.text.strip('"')
     headers = {
  5. Open the file in binary mode and upload it using the signed URL:
     with open(file_name, "rb") as file:
          upload_headers = {"Content-Type": "application/json"}
          put_response = requests.put(signed_url, data=file, headers=upload_headers)
     put_response.raise_for_status()
     print("File uploaded successfully")
  6. Save the script and run it:
    python upload_to_peak.py
Result​
Your file uploads to Peak's file storage. The script outputs the upload status. The file becomes available for processing according to your configured data feeds and triggers.
Complete example script​
Here is a complete Python 3 example that generates a signed URL and uploads a file:
import os
import requests
import sys
def upload_file_to_peak(file_name):
    """Generate a signed URL and upload a file to Peak."""
    tenant_api_key = os.environ.get("peak_tenant_api_key")
    if not tenant_api_key:
        print("Missing environment variable: peak_tenant_api_key")
        return False
    try:
        # Step 1: Generate signed URL.
        signed_url_endpoint = "https://api.peak.ai/file/signedurl/client"
        signed_url_headers = {
        signed_url_payload = {"fileName": file_name}
        print("Generating URL...")
        first_response = requests.post(
            signed_url_endpoint,
            json=signed_url_payload,
            headers=signed_url_headers,
        if first_response.status_code != 200:
            print(f"Signed URL request failed with status code: {first_response.status_code}")
            print(f"Response: {first_response.text}")
            return False
        signed_url = first_response.text.strip('"')
        # Step 2: Upload file with signed URL.
        print("Uploading file...")
        with open(file_name, "rb") as file_obj:
            put_response = requests.put(signed_url, data=file_obj, headers=upload_headers)
        if put_response.status_code == 200:
            print(f"File {file_name} uploaded successfully")
            return True
        print(f"Upload failed with status code: {put_response.status_code}")
        print(f"Response: {put_response.text}")
        return False
    except FileNotFoundError:
        print(f"File not found: {file_name}")
        return False
    except Exception as e:
        print(f"Error during upload: {e}")
        return False
# Usage
success = upload_file_to_peak(file_name)
if not success:
    sys.exit(1)
import os
import requests
import sys
        return False
    try:
            return False
            return True
        return False
        return False
        return False
# Usage
if not success:
    sys.exit(1)
Next steps​
After the file is uploaded to the Peak data lake, create a feed and schedule it for recurring ingestion. For details, see Creating a file feed from Files.
Troubleshooting​
If you encounter errors during upload, refer to the following common issues and solutions:
  • 403 Forbidden - The signed URL may have expired. Request a new signed URL.
  • 401 Unauthorized - Verify that the Authorization header contains a valid tenant API key.
  • 400 Bad Request - Verify that the signed URL request body includes a valid fileName value.
  • FileNotFoundError - Check that the file path is correct and the file exists.
  • Connection errors - Verify your network connection and firewall settings.
