industry-department-solutions
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
SKU calendar dataset
SKU calendar dataset containing active date ranges for products at locations, including discontinuation end dates, used by Rebuy & Replenishment.
The SKU calendar dataset contains the active date ranges for products at locations, including discontinuation end dates. It defines when a product is available for sale at a given location.
Purpose​
The Rebuy & Replenishment capability uses the SKU calendar dataset to understand when products are active at each location. This allows the solution to exclude periods when a product was not yet active or has been discontinued, improving the accuracy of demand analysis and recommendations.
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
product_idUnique identifier for the product.stringPrimary key
location_idUnique identifier for the location.stringPrimary key
start_dateDate the product becomes active at the location.dateNullable
end_dateDate the product is discontinued at the location. Required for discontinued products.dateNullable
Usage notes​
  • This dataset is optional and helps refine analysis by identifying active and discontinued periods.
  • Provide end_date for discontinued products so they can be excluded from forward-looking recommendations.
  • Product and location identifiers must align with the corresponding Products and Locations datasets.
  • Active date ranges should reflect actual product availability at each location.
  • Purpose​
  • Required fields​
  • Usage notes​
