industry-department-solutions
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
Purchase orders dataset
Purchase orders dataset containing details of supplier orders, used by Rebuy & Replenishment to project future inventory availability from inbound procurement.
The purchase orders dataset contains details of orders placed with external suppliers to replenish stock or raw materials, disaggregated by order number. It provides a history of purchase orders, including amendments, and is used by the Rebuy & Replenishment capability to project future inventory availability.
Purpose​
The Rebuy & Replenishment capability uses the purchase orders dataset to:
  • Account for stock on order when calculating inventory positions
  • Generate stock parameters based on the total of on-hand stock and incoming supply
  • Project future availability and support replenishment recommendations
By incorporating open and incoming purchase orders, the solution evaluates inventory exposure based on actual supply in transit, not just current on-hand stock.
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
product_idUnique identifier for the product SKU.stringNon-null
location_idUnique identifier for the store or distribution centre.stringNon-null
order_numberUnique identifier for each purchase order.stringPrimary key
source_idUnique identifier for the supplier.stringNon-null
ordered_atDate and time (UTC) when the purchase order was placed.datetimeNon-null
order_due_dateDate and time (UTC) when items on the purchase order are due to arrive.datetimeNon-null
ordered_unitsNumber of units ordered for the purchase order line item.floatNon-null
receipted_atDate and time (UTC) when items on the purchase order were received.datetimeNullable
receipted_unitsNumber of units received for the purchase order line item.floatNullable
order_line_valueCost price of units ordered for the purchase order line item.floatNon-null
order_line_statusStatus of the purchase order line item (for example, Open, Pending approval, Closed).stringNullable
Usage notes​
  • Purchase orders should be provided at line-item level to support accurate inventory projections.
  • Both open and completed purchase orders should be included to preserve historical context.
  • Partial receipts should be reflected using receipted_units and receipted_at fields alongside the original ordered quantities.
  • Identifiers (product_id, location_id, source_id) must align with the corresponding Products, Locations, and Suppliers datasets.
  • Units of measure must be consistent across purchase orders, stock, and demand datasets.
  • Purpose​
  • Required fields​
  • Usage notes​
