industry-department-solutions
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
Reauthorizing a Snowflake OAuth connection
Reauthorize an expired Snowflake OAuth connection in Peak when the 90-day refresh token has expired, to restore data warehouse access.
When you authorize a Snowflake OAuth connection, Peak receives a refresh token that it uses to generate access tokens for your data warehouse. The refresh token is valid for 90 days by default and can be extended up to 1 year by request through Snowflake.
If the refresh token expires, Peak cannot generate new access tokens and all platform operations that require the data warehouse will stop working. There is no automated renewal — you must reauthorize manually.
Prerequisites​
Before reauthorizing a Snowflake OAuth connection, ensure you have the following:
  • Your Snowflake data warehouse is connected to Peak using OAuth.
  • You have access to the Snowflake user that has the role configured in Data Bridge. To check the configured role, select the expand icon on the data warehouse panel in Data Bridge.
Steps​
  1. In Peak, open Manage and select Data Bridge.
  2. In the data warehouse panel, select Reauthorize.
  3. Sign in to Snowflake using a user that has access to the configured role.
  4. After signing in, you are redirected back to Peak. The success or failure of the reauthorization is displayed on the platform.
Result​
Peak can generate new access tokens and continue using the Snowflake connection.
  • Prerequisites​
  • Steps​
  • Result​
