industry-department-solutions
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
Quote line dataset
Detailed line-item information for customer quotes, capturing the pricing decisions and behavioral data used in Commercial Pricing analysis.
The Quote Line dataset contains detailed line-item information for customer quotes. It represents individual pricing decisions made during the quoting process and provides the core behavioral data used to analyze quote performance.
This dataset is required for application deployment and pricing insights analysis.
→ For the canonical technical schema (data types, validation rules, request/response examples), see Quote Line in the API Guide.
Purpose​
The commercial pricing solution uses the Quote Line dataset to:
  • Analyze quoted prices at the product and customer level
  • Evaluate win/loss behavior in response to pricing decisions
  • Measure discounting patterns relative to list price
  • Support pricing recommendations for future quotes
This dataset is essential for Quote Pricing use cases.
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
quote_idUnique identifier for each quote.stringPrimary key
product_idUnique identifier of the product.stringPrimary key
original_quote_idUnique identifier of the original quote being re-optimisedstringNullable
quote_statusStatus of the quote (won, lost, pending, or archived). Used in model training to learn which quotes converted.stringNullable
price_list_idPrice list used for this quote.stringNullable
quoted_atTimestamp when the record was quoted.timestamp_tzNon-null
decided_atTimestamp when the quote was decided — when it was won, lost, cancelled, or replaced.timestamp_tzNullable
customer_idUnique identifier of the customer.stringNullable
merchant_idUnique identifier of the merchant.stringNullable
project_idUnique identifier of the project.stringNullable
region_idUnique identifier of the region the quote applies to.stringPrimary key
quantityQuantity of the product in the quote. Used as a feature in model training as the quantity demanded impacts the optimal price.floatNon-null
selling_priceSelling price for the product. The price on the quote for the product. Used to calculate the discount applied to the quote for model training.floatNon-null
Custom fields​
The fields listed previously are the standard schema for this dataset. A field that your business requires but the standard schema does not include can be added as a custom attribute after the schema is rolled out. Custom attributes are additive, so they extend the dataset without affecting existing fields, and they are validated in the same way as standard fields.
The following request adds a DISCOUNT_REASON column to this dataset:
curl -X POST \
  'https://ingestion.peak.ai/api/v2/schema/QP_QUOTE_LINE_OOTB/add-attribute' \
  -d '{
    "solutionName": "QP_OOTB",
    "columnName": "DISCOUNT_REASON",
    "dataType": "string",
    "validations": [
      { "type": "optional" }
curl -X POST \
  -d '{
    "validations": [
The table name in the request URL is this dataset's fully qualified warehouse name, which includes the prefix and suffix configured when your solution was rolled out — QP_QUOTE_LINE_OOTB in this example. Retrieve the name for your own solution with Describe a solution's schema.
On standard tables the API prefixes the new column name in the warehouse with C_ (Snowflake) or c_ (Redshift), so DISCOUNT_REASON becomes C_DISCOUNT_REASON and warehouse queries must use the prefixed name.
→ For the full parameter reference, supported data types, and validation rules, see Customizations in the API Guide.
Usage notes​
  • All referenced identifiers (product_id, customer_id, merchant_id, project_id) must exist in their corresponding datasets.
  • Quote lines should reflect actual quoted pricing behavior, not list prices.
  • Quote stage information helps differentiate early-stage quotes from finalized quotes.
  • Historical quote data improves pricing model accuracy and recommendation stability.
  • Units of measure must align with related datasets (Products, Sales).
  • Purpose​
  • Required fields​
  • Custom fields​
  • Usage notes​
