industry-department-solutions
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
Stock extra dataset
Stock extra dataset for the Markdown & Promotions module, breaking down daily inventory levels by product variant.
The Stock extra dataset provides daily inventory levels broken down by product variant, for cases where a single product is stocked in multiple variants.
Purpose​
The Markdown & Promotions module uses the Stock extra dataset to:
  • Capture variant-level stock where a product has multiple variants
  • Support availability analysis at a finer grain than the product-level Stock dataset
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
product_idUnique identifier for the product SKU.stringPrimary key
Foreign key to product
location_idUnique identifier for the store or location.stringPrimary key
Foreign key to location
product_variantIdentifier for the specific product variant (for example, size or colour).stringPrimary key
stock_date_atDate of the stock snapshot.datePrimary key
created_atTimestamp when the record was created.timestampNullable
stock_idSource-system identifier for the stock record.stringNullable
stock_unitsNumber of units in stock on the given date.integerNon-null
updated_atTimestamp when the record was last updated.timestampNullable
Usage notes​
  • Provide this dataset only where variant-level detail is required.
  • Product and location identifiers must align with the Products and Locations datasets.
  • Values should reconcile with the product-level Stock dataset.
Why this dataset matters​
Variant-level stock lets the solution assess availability for sized or variant-based ranges that a single product-level record cannot represent.
  • Purpose​
  • Required fields​
  • Usage notes​
  • Why this dataset matters​
