industry-department-solutions
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
Stock dataset
Stock dataset for the Markdown & Promotions module, containing daily inventory levels per product and location.
The Stock dataset contains daily inventory levels for each product at each location. It provides the availability context used to ensure markdown and promotion actions are operationally feasible.
Purpose​
The Markdown & Promotions module uses the Stock dataset to:
  • Provide current and historical inventory levels by product and location
  • Assess availability and exposure for ageing or excess stock
  • Support clearance and markdown decisions
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
location_idUnique identifier for the store or location.stringPrimary key
Foreign key to location
product_idUnique identifier for the product SKU.stringPrimary key
Foreign key to product
stock_date_atDate of the stock snapshot.datePrimary key
created_atTimestamp when the record was created.timestampNullable
stock_idSource-system identifier for the stock record.stringNullable
stock_unitsNumber of units in stock on the given date.integerNon-null
updated_atTimestamp when the record was last updated.timestampNullable
Usage notes​
  • A daily record of stock levels is recommended to support accurate analysis.
  • Stock quantities should use the same unit of measure as related datasets (for example, Sales).
  • Product and location identifiers must align with the Products and Locations datasets.
Why this dataset matters​
Stock levels determine which products carry clearance or markdown risk. Without accurate stock data, recommendations may target the wrong products.
  • Purpose​
  • Required fields​
  • Usage notes​
  • Why this dataset matters​
