industry-department-solutions
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
Files overview
Files feature in Peak for viewing and managing data lake files, with a folder structure mirroring the underlying storage and key default folders described.
Files is available in Manage and gives you direct access to files in your Peak data lake. The interface mirrors your data lake structure so you can view and manage files without leaving Peak.
Home folders​
The Files home screen includes the following folders:
  • datascience - Used mainly for processed and intermediate data.
  • mlflow - Used for files generated by Model Management.
  • output - Used for output data, including downloadable insights.
  • uploads - Contains files uploaded directly through ad hoc upload.
  • raw - Staging location for data feeds.
  • adhoc_file_exploration - Contains files uploaded for SQL Explorer exploration.
Use the breadcrumb path at the top of the screen to move up through the folder structure.
To search for files or folders, enter a full or partial name in the search bar. Search results are limited to the folder scope you are currently viewing.
Manage folders, uploads, and feeds​
Files supports folder and file operations directly from the interface:
  • Create and delete folders in locations where you have write access.
  • Upload and delete files in locations where you have the required permissions.
  • Create file feeds from file actions.
For step-by-step procedures, see:
Filter folder contents​
You can filter folder contents and apply one or more criteria. Active filters are displayed under the folder title.
Available filter options include:
  • Type - Filters by file or folder type (for example, CSV, JSON, PDF).
  • Last updated by - Filters by tenant user who most recently updated the file.
  • Date range - Includes presets such as last week, last 15 days, and last month.
  • File size - Includes ranges such as up to 50 KB, 50 KB to 1 MB, 1 MB to 5 MB, and above 5 MB.
Action menus​
Folders and files include an action menu at the end of each row.
Folder action menu options include:
  • View folder
  • Copy path
  • Copy URL
  • Delete
File action menu options include:
  • View
  • Create feed
  • Copy path
  • Copy URL
  • Download
  • Delete
View file contents and file information​
When you open a file, Files provides two tabs:
  • View File - Preview file content.
  • Information - View metadata and copy the absolute file path.
Supported preview file types include:
  • csv
  • xml
  • json
  • txt
  • jpeg
  • jpg
  • png
For non-image files, available preview formats can include:
  • Raw
  • Table
  • Code
Preview size behavior:
  • Files up to 64 KB can be previewed directly.
  • For larger files, Files shows a sampled preview.
  • Images up to 5 MB can be previewed in the interface.
